Author Topic: CB750 shock length  (Read 2709 times)
Offline Wbflyer
CB750 shock length
« on: July 23, 2017, 04:53:05 PM »
What is the best rear shock length to use?  I am 6'3" and want to make a brat..scrambler type of build.  I was thinking 13 inch shocks?
Offline Jnel
Re: CB750 shock length
« Reply #1 on: July 23, 2017, 06:14:28 PM »
I'm 6' 1"  and I put 13.5 inch shocks on this frame.  On the lowest setting, this the stance.  FYI
Sent from my SAMSUNG-SM-N930A using Tapatalk
Offline Wbflyer
« Reply #2 on: July 23, 2017, 09:14:11 PM »
I like that stance!
« Reply #3 on: July 23, 2017, 09:19:02 PM »
Contact Nils at Restocycle.com  He's a member and IKON shock dealer (and offers a discount to forum members).  He can order you a shock to fit your specific purpose, height and weight.
Offline DaveBarbier
CB750 shock length
« Reply #4 on: July 24, 2017, 04:48:18 AM »
The settings on the shocks aren't height adjustments. It'll always be the same height. The setting is for spring stiffness. Stiffer for riding with gear and 2 up, softer setting for a solo skinny bastard.
« Reply #5 on: July 24, 2017, 07:14:57 AM »
+1... I put Ikon's on my K3
« Reply #6 on: July 24, 2017, 08:23:26 AM »
I may be wrong, but I believe IKONS can be custom ordered as to length and the spring.  If Wblfyer is going to go offroading he should consider a longer shock with more travel and appropriate springs to soak up bumpy dirt roads.
Offline Wbflyer
« Reply #7 on: July 24, 2017, 09:12:27 AM »
excellent, thanks!
