Author Topic: Modern Nissin front master brake switch connection  (Read 1326 times)
Offline SKTP
« on: July 23, 2017, 11:49:21 PM »
What is this brake switch connection called and where do a buy the "switch wire/harness" that mates with it? I've googled everything I can thing of with no luck. There has to be a nice clean female plug for this?
« Last Edit: July 23, 2017, 11:51:28 PM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Online RAFster122s
Re: Modern Nissin front master brake switch connection
« Reply #1 on: July 24, 2017, 12:06:03 AM »
In the stock setup the brake switch is off of the junction block and it is a hydraulic switch. You will need to disregard this if you maintain the pressure switch or move your wiring to the handlebar.  It is breaking the path for the power to flow in the brake light circuit until you apply the brakes.
You may need to extend the wires and pick up some .187 or .250" quick disconnects and insulate those ends against an unintentional short circuit.
David
Offline SKTP
« Reply #2 on: July 24, 2017, 12:19:36 AM »
I am not using, nor do I have a hydrodrolic junction box switch. I want to use that switch and the femsle plug that goes with it. I will modify the other end to use bullet connectors that plug into the harness.
I am trying to figure out what the female connector to that switch is. It must be fairly common in newer bikes?
« Last Edit: July 24, 2017, 12:21:13 AM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Bailgang
  • Scott
  • Indiana
« Reply #3 on: July 24, 2017, 01:39:02 AM »
Not sure if my kids cbr has a "bulk" female connector on his, I'd have to take a look at his to make sure but my 83 GL1100 has 2 separate small female spade connectors from the factory and come to think of it so far every bike I've worked on (which isn't all that many) that has had that style brake switch used 2 separate female spade connectors as well.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Garage_guy_chris
« Reply #4 on: July 24, 2017, 01:41:52 AM »
On newer Honda's there is no molded female plug its just 2 wires with 2 separate insulated spade connectors
Offline SKTP
« Reply #5 on: July 24, 2017, 10:21:20 AM »
Thanks guys...appreciated...will find the correct spade connections
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #6 on: July 24, 2017, 11:20:44 AM »
This.  Seems OP is on the right track now 😁
