Author Topic: usb port, voltmeter  (Read 2203 times)
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: usb port, voltmeter
« Reply #25 on: July 30, 2017, 07:55:10 AM »
is there a specific amperage range to stay in for the bike when looking for one of these gadgets?
cb750 k6 - ugly
Online Deltarider
« Reply #26 on: July 30, 2017, 08:30:20 AM »
I don't know what you mean. Measuring volts and ampères are two different things. Old British bikes used to have ampère gauges and so does Enfield (made in India) but although ampèremeters are not very accurate, they do tell you when the system charges or decharges. Some bikes (Italian and some old Yamaha's) had a red light coming on when the dynamo failed. Kawasaki on some models had the tachometer double as a Voltmeter (you had to press a button and you could read the voltage instead of the rpm) an elegant solution. All in all a voltmeter gives a better indication of the 'health' of the system but, quite frankly, IMO you don't need one.
« Last Edit: July 30, 2017, 08:44:45 AM by Deltarider »
Offline evinrude7
  • not a kung-fu
« Reply #27 on: July 30, 2017, 10:38:34 AM »
You don't follow my question because I don't know what I'm talking about.   is there a specific range electrically speaking one should stay between when looking for one of these units?
Sent from my LG-H871 using Tapatalk
cb750 k6 - ugly
« Reply #28 on: July 30, 2017, 10:41:40 AM »
Voltmeters measure potential.  So, you need only ensure it is able to withstand the max voltage expected in the application.  Amperage doesn't matter.
Ammeters measure the push in electrical circuits.  They include a shunt to measure the voltage drop across it, as the meter is inserted into the circuit under test.  Again, you must ensure the meter's shunt is capable of withstanding the expected maximum employed in the circuit under test.
Offline evinrude7
  • not a kung-fu
« Reply #29 on: July 30, 2017, 12:57:01 PM »
ok i was wondering if any of the units out there would pull too much power on these bikes.
cb750 k6 - ugly
« Reply #30 on: July 30, 2017, 01:03:28 PM »
No, not for this application.
