Author Topic: Petcock pissing in garage  (Read 1332 times)
Offline SG103
« on: July 30, 2017, 11:16:06 AM »
The petcock on my CB750F will piss on my motor overnight after I put the bike in the garage and shut off fuel. Anyone else have this issue? When I go into the garage in the morning there is a strong smell of gas.
Arnold
« Last Edit: July 30, 2017, 11:17:48 AM by SG103 »
Offline Smudgemo
  • Maker of Stuff
Re: Petcock pissing in garage
« Reply #1 on: July 30, 2017, 11:52:43 AM »
I recently put a NOS 750 petcock on my 550F and it definitely does not close off the fuel supply.  About half the time the carbs leak fuel when I roll it out of the garage, and sometimes it drips in the garage.  I guess I've got two fixes to address.  Replace or rebuild the petcock, and figure out which carb(s) are not sealing properly.  The carb issue is a pain, but not unexpected.  The petcock not properly working really annoys me, though.
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
    • http://forums.sohc4.net/index.php?PHPSESSID=479idisjq04be28maftv0aa053&/topic,60973.0.html
« Reply #2 on: July 30, 2017, 12:26:45 PM »
some years have a plastic cone valve..and they can easy vear aut and internal leaking through the tap..and fill the carbs or leak.(.74-76 modells)..i think.. and is not to  easy to fix.
later plate type vith 4 holes is easy to go on..just a nev rubber plate.(rep set).and it vorks fine
« Reply #3 on: July 31, 2017, 08:50:14 AM »
Rebuild it.  Worn internals.
« Last Edit: July 31, 2017, 11:13:47 AM by flybox1 »
Offline Gene
  • Chat enuf you too can be a
« Reply #4 on: July 31, 2017, 11:11:09 AM »
A quick fix - tho not permanent by any means - is to create a short piece of fuel line and run a "U" from one petcock outlet to the other. You can do that while you're waiting for your replacement petcock, parts, or for storage.
I know this doesn't help, but again, a short-term storage fix.
*1973 CB750K3 (Bow)
Offline johnbkobb
« Reply #5 on: July 31, 2017, 03:26:34 PM »
Where are the carbs leaking from? bowl seal, overflow tube?
Offline carnivorous chicken
« Reply #6 on: July 31, 2017, 07:18:12 PM »
750F petcocks are riveted, not bolted together (at least the ones I've seen, from 75-78). And there is more than one size -- the medium size being hard to find, although I bet someone here has a line on them. The overflow at the carb may be exacerbated by a petcock that doesn't turn off, but it's its own problem.
Offline jgger
« Reply #7 on: July 31, 2017, 07:31:06 PM »
Try shutting the gas off and letting it run for a bit before you shut down the motor and park it on the center stand. Running the fuel down in the carb bowls can rule out heat expansion of the fuel if the floats are set just a tad high.
« Reply #8 on: August 01, 2017, 06:52:32 AM »
Not his carbs....his petcock
« Reply #9 on: August 01, 2017, 07:07:31 AM »
Ahh.. I made that mistake too, but it was from the second post.
One thing to try: on the CB750F there is an o-ring where the petcock mounts. I had a leaking petcock but it was just that o-ring, and before I replaced it it was a little hard to tell where the leak was from. unless you're sure it's coming out of the petcock body, might try that first.
« Reply #10 on: August 01, 2017, 07:17:43 AM »
Yes, and you are correct that they are riveted.  Had to check mine again last night.
If that o-ring(K7/8s, too) between the pet and the tank is chewed up or disintegrated, it will easily leak around this collar.
Viton/Buna are the best options here.
« Reply #11 on: August 01, 2017, 07:44:37 AM »
you can drill the rivets and drill and tap the holes to a 3mm schrev/...
« Reply #12 on: August 01, 2017, 07:50:21 AM »
Also true. The round rubber bit inside with the holes (I know, technical term...) is replaceable on some, but I think the medium sized one is tough to find. I can't remember the measurements on the tap on these petcocks so I'm bring vague -- anyone else here help? the larger and smaller sized ones are available as repops for about $20, but I've had trouble sourcing the in between one.
Offline lrutt
« Reply #13 on: August 01, 2017, 12:48:33 PM »
You can drill the rivets then tap the hold for a small screw. I've done that many times. Of course after you've replaced the holey donut inside.
« Reply #14 on: August 01, 2017, 12:55:24 PM »
That's the technical term I was looking for.
Offline SG103
« Reply #15 on: August 01, 2017, 01:52:38 PM »
Thanks to all who have replied. If I line up the start of the notch on the handle with the "R" in RES, it doesn't leak at all, so not quite pushed to the end, and the fuel IS shut off. I will go with that for now. I notice as soon as I walk in the garage if it's leaking, gas smell.
Arnold
