Author Topic: Yamiya Oil Seal Kit cb750  (Read 1649 times)
Offline TheArchitect
« on: August 02, 2017, 01:35:21 PM »
Does anyone have any experience with these?
http://www.yamiya750.com/index.php?main_page=product_info&cPath=246_21_250_155&products_id=125
It comes in a red and white shrink wrapped pack "ARX" made in japan "for professional use"
I found that CMNSL carries the same brand for other hondas as well.
Is it a mistake to throw these in there?  I know nothing beats honda quality, just wanted to see if anyone has had success with these since I have them...
Thanks!
1978 CB550
1975 CB750
Offline disco
Re: Yamiya Oil Seal Kit cb750
« Reply #1 on: August 03, 2017, 02:32:15 AM »
I used them on my 836 build. No problems so far.
The only one that is really difficult to change out is the crank seal near the points. If that goes "tits up" that would be a bummer.
« Last Edit: August 03, 2017, 02:34:12 AM by disco »
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline drumstyx
« Reply #2 on: August 03, 2017, 08:21:19 AM »
You need to split the cases to do that one, no?
« Reply #3 on: August 03, 2017, 08:33:18 AM »
Yes...it has a lip.  It cant be pressed in like many others.
Offline Nic
« Reply #4 on: August 03, 2017, 03:22:47 PM »
I put an aftermarket seal kit in my K2, I think it was the Crusin Image one, anyway, 5,000 Kays later the points seal went bad. Being as it's so much fun to replace that seal I would put Genuine Honda in from now on.
Offline tlbranth
« Reply #5 on: August 05, 2017, 10:26:38 AM »
My points seal is leaking. How difficult is it to replace? I assume the whole case has to have its mating surfaces scraped and resealed.
I wonder iif it would be possible to just pry out the old one and hammer in a new seal sans lip. eh?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Nic
« Reply #6 on: August 05, 2017, 09:31:15 PM »
You have to split the cases, it's a nice casual weekend job, or a day rush job, take out the cam chain tensioner so you can lift the crank up on the points side enough to slide the new seal on. Worst bit is taking out the engine. Yep, clean and reseal cases too. I tried normal un-lipped seal first, tapped it in with sealant, no good. Make sure to use Gen Honda seal.
Offline tlbranth
« Reply #7 on: August 06, 2017, 09:13:48 AM »
Bummer. What kind of junk are these seals made of anyway? 47 years and the bugger leaks.
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #8 on: August 07, 2017, 07:40:06 AM »
If youre headed out to the reunion, just acetone clean that area really well, add a schmear of some non-hardening sealant, and ride it till you cant stand the thought of some unseen sealant keeping oil from not leaking behind your points cover.  ;D
