Author Topic: 78 cb550 pd46c carb manifold o ring gasket ??  (Read 1880 times)
Offline evopgt
« on: August 05, 2017, 10:16:37 AM »
Does anyone have a part number for the o ring gaskets between the intake manifold and engine block?? 78 cb550 pd46c carbs. Mine seem to be kind of flat and may not produce a proper seal. Thanks
Offline CycleRanger
  • No comment about being an
Re: 78 cb550 pd46c carb manifold o ring gasket ??
« Reply #1 on: August 05, 2017, 10:35:42 AM »
You can download the parts list here:
http://honda4fun.com/materiale-documentazione-tecnica/parts-list/parts-list-cb550
PN 91302-001-020
Although I have seen mentioned that other folks have used the more common and cheaper 30x3.5mm o-rings for this application.
Offline evopgt
« Reply #2 on: August 05, 2017, 11:00:46 AM »
Thanks for that list! Got 4 for about $12.50 from 4into1.com
« Last Edit: August 05, 2017, 11:04:48 AM by evopgt »
Offline Deltarider
  • I'm back
« Reply #3 on: August 05, 2017, 11:06:45 AM »
Same O-rings that are under the 8 valve adjust covers, ⌀ 30,8 mm and they're widely available.
CB500K2-ED Excel black
Offline CycleRanger
« Reply #4 on: August 05, 2017, 11:13:06 AM »
30.8 x 3.2mm  widely available but pricey at ~$2.50 or so each.  :P
Unless you have a cheap source.
Offline Deltarider
  • I'm back
« Reply #6 on: August 06, 2017, 03:59:16 AM »
It's better to use the parts list itself. In the first few pages of every parts list you can determine what specific model you have. Not only that, the list will give you the complete overview and you'll spot differences between models for various markets. Then you can judge what part meets your desire best. An example: if the PO has changed the handlebars for those that were on models for Europe and you, unaware of this, would order cables that you've found in those fiches, you'll end up with the wrong ones. This has happened more than once. Just consult the original parts list and you'll have the complete story. As a bonus you'll understand more about your bike.
