Author Topic: A Noob's 75 CB550 Cafe Project Thread ------- Stick a fork in it... ;-)  (Read 212738 times)
Offline doug_id
    • My Cafe 550 Project Gallery
more misc stuff
« Reply #200 on: February 15, 2007, 07:57:58 PM »
Installed new starter switch with cover.....like this better than the cheap looking plastic one.
Installed small filter on breather outlet.  Got it from Dennis Kirk......
http://www.denniskirk.com/jsp/product_catalog/Product.jsp;jsessionid=ZYVRB2LF4QYCDLA0WTISM4VMDK0OWIV0?store=Main&skuId=301755&productId=p301755
02 Concours
78 CB550
06 Stella 150 2t Scooter
Offline doug_id
Ready to start it?
« Reply #201 on: February 15, 2007, 08:01:07 PM »
Well, I need to put gas in the tank and I will squirt a small amount of engine oil in each spark plug hole.  Is there anything else I should check for or do prior to trying to fire up the engine?   Almost as nervous as I was on my first date..... :o ;)
02 Concours
78 CB550
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
Re: A Noob's 75 CB550 Cafe Project Thread
« Reply #202 on: February 15, 2007, 09:49:38 PM »
         Hey doug,
                   No advice here, just compliments. Your bike looks super! 8) There is nothing that I don't like about your bike. Everything has turned out so well. I'm waiting to hear about how those Dunlop K70s do also. I'm seriously wanting some for mine (as you already know) and thanks again for that link to where you got yours. You take care and I'll catch you later on,  Bill :) ;)
Member # 1969
Offline gregwaits
  • Damn, riding a CB750 sure is fun!
    • waits music
« Reply #203 on: February 15, 2007, 09:58:12 PM »
I really dig that tank. I am sure you've already been asked where you got it, so I'll spare asking again! I'll scroll back and find what you said.
Good work!
1978 CB750K8; 1970 CB450
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #204 on: February 15, 2007, 10:29:36 PM »
It was Benji's if I recall Greg  :)
That is one sweet looking bike, I can't believe how high you've set the bar now, especially as you're 'allegedly' a newbie >:( ;)
The only advice I'd give you there at this point oug is to spin the motor up without sparks first, just to make sure you've got oil pressure, don't learn the hard way like I did with my VW Beetle ;)
I'm not just liking them pipes now they are fitted, I'm loving them 8)  They look so much like my folk's neighbour's Enfields 8) 8)
What is the fit & finish like, I may be acquiring a set for my 550 8) Will he do slight mods for you, the sketches I'm coming up with for mine want the pipes to be upswept more, so that you can see/access the spindle beneath them :)
I'm with Bill too, let us know on the tyre front
1978 CB550 K3
1985 H100S
Offline doug_id
« Reply #205 on: February 16, 2007, 06:32:30 AM »
Thx everyone.... ;D....I will try to start it up today.....so should I kick it a while with the ignition off to get the oil circulating???
Chris the fit and finish on the pipes is top notch.......I couldn't find a single blemish on the set I have.
02 Concours
78 CB550
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #206 on: February 16, 2007, 06:55:09 AM »
Yes...
Do more than a couple good kicks to get some oil circulated before you attempt to actually start it..
Offline CrisPDuk
« Reply #207 on: February 16, 2007, 07:48:10 AM »
Spin it over with the starter for a minute or two, with the kill switch off. Then check you've got oil at the top of the engine. You're always better safe than sorry :)
1978 CB550 K3
1985 H100S
« Reply #208 on: February 16, 2007, 07:48:33 AM »
As Proteal said you can kick it over a couple of times to get oil circulating or as I was told, use the starter button with kill switch off (so it wont actually start) but will turn starter motor over and get oil into head - keep finger pressed on starter button for about 10 sec bursts and do this for about 5 or 6 times. Then open up tappet covers and start bike and make sure oil is getting to the head! Keep it on idle for a while to allow oil to circulate.
good luck!
cheers
Andy
Offline doug_id
Starting First Attempt
« Reply #209 on: February 16, 2007, 09:05:47 AM »
Well.......looks like one carb has a stuck float or the float is set to high.....fuel running out of overflow tube.    So it begins......the real fun!   ;D
Wondering if just stuck float if a couple of taps with a rubber mallet might help.......?
Another thing I noticed is no matter what position I set the petcock to the fuel keeps coming out of the overflow valve tube....wonder what is up with that?
02 Concours
78 CB550
Offline Gordon
  • 750K1, 550K2
« Reply #210 on: February 16, 2007, 09:09:25 AM »
A couple of taps with the handle of a screwdriver will sometimes do the trick if the float valves are stuck open, and it sounds like you might need a petcock rebuild kit.
Offline doug_id
« Reply #211 on: February 16, 2007, 09:10:21 AM »
ok...will try that.....not sure what is going on with the petcock.....brand new it is....lol.
02 Concours
78 CB550
Offline Gordon
  • 750K1, 550K2
« Reply #212 on: February 16, 2007, 09:13:15 AM »
Uh-oh! :-\
tmht
Re: Starting First Attempt
« Reply #213 on: February 16, 2007, 09:56:24 AM »
Takes a while for the carb to drain completely. Pull the fuel line off the tank and hold a suitable container under the spigot on the petcock and check for leaks...
Rubber mallet, end of a screwdriver, lead/brass hammer, all would be a suitable "float un-sticking aparatus". When I fire my 400 up for the first time after the carbs have be off and apart they will do the same thing about 60% of the time. Couple of quick taps after the engine has been running for a few seconds takes care of it every time. (sometimes the vibes from the engine do the trick.)
Offline doug_id
« Reply #214 on: February 16, 2007, 09:57:51 AM »
well, pulled one of the plugs and held tip to exhaust while turning it over....don't see any spark.....that is a surprise....hehe!   Wonder if something not grounded ....either that or I missed a connection somewhere...... ::)
02 Concours
78 CB550
Offline WJL75
« Reply #215 on: February 16, 2007, 10:21:09 AM »
Swap plugs and see if it still happens. It may just be a bad plug.  Make sure to swap it with a plug off of a different coil.  Good Luck!
wjl75
1976 CB550K Cafe
Offline doug_id
« Reply #216 on: February 16, 2007, 10:45:09 AM »
Tried with two different plugs and nada....pulled the cover off the points and while starter was turning over used wire tester on both the green and yellow wires....zip....looks like no juice flowing into them.  Thinking a bad ground somewhere or a missed wiring connection?
Rubber malleted the bad carb several times and no luck......looks like I will have to wait for the fuel to drain out that bad carb and then pull them....I probably made a mistake putting that one back together......good news is all the float bowl gaskets seem to be sealed good    ;D
I am leaving for a rafting trip in the early am tomorrow....hopefully all the gas will be drained when I get back....hehe.
Thx everyone for the tips/suggestions!
02 Concours
78 CB550
tmht
« Reply #217 on: February 16, 2007, 11:36:27 AM »
It shouldn't take more than 10-15 minutes for it to drain completely. Did you make sure the petcock is holding?
Offline kine8282
  • "Ceteris paribus, my modis operandi is carpe diem"
« Reply #218 on: February 16, 2007, 11:54:41 AM »
Doug...regarding your "no spark" issue not sure if you already checked but I would double check the new all-in-one control kill-switch, for some reason that's always a problem
my 2 centavos...cant wait for the shocks!
1975 CB550K aka "Nefertiti"
1978 CB750K aka "Kate"
Offline doug_id
« Reply #219 on: February 16, 2007, 12:24:55 PM »
Hi,
well, I pulled the tank....just stuffed some rages under it and loosened the line clamps and pulled it quick and sat it down on a bucket.......the off postion slows the fuel flow somewhat but does not stop it.   I am letting the gas drain into a bucket now.  Next week I will take the petcock off and see what is going on....also fuel was almost exclusively coming from one outlet only on the petcock not both evenly.....maybe relelated issues.
02 Concours
78 CB550
Offline doug_id
« Reply #220 on: February 16, 2007, 12:31:15 PM »
Not sure what is going on yet....all the other electical systems are working fine.   I took the tank off and dremeled more around the ground connection for the coils thinking maybe it wasn't grounded.   I poked around with a line tester with the starter motor turning over but did not register any power at the coils.   Not 100% sure I am checking the right wires in the right way....not to good with electrical systems.   I also checked the green and the yellow wires going into the points and didn't see anything register there either.
Quitting for now and putting everything away.   Work on it more monday or tuesday when I have more time.
Thx everyone for the help!   8)
02 Concours
78 CB550
Offline doug_id
« Reply #221 on: February 16, 2007, 12:51:27 PM »
Im surprised no one else chimed in on the fork brace, but yes, I would put a fork brace on if I were you.  Do you still have the front fender?  If you flip it you'll see there is a bracket on the underside that is welded to the fender, the part that bolts to the forks.  I remeber seeing where Proteal(I think) separated that bracket from the fender, painted it black so as to be inconspicuous and mounted that part alone between the forks.  Worked well for him if I recall.  With a bike like that, your gonna want to tear up some twisties a fork brace is going to make the front end alot more stable.  Good luck with the fuel/ignition problems and have a nice trip!
Yes, I still have the original fender....I will have to check that idea out and see what I can do....I have seen the heavy dute fork braces on e-bay but just looking at how far up the forks my front tire is I don't see how they would fit.   ???
02 Concours
78 CB550
Offline TomC
« Reply #222 on: February 16, 2007, 06:15:11 PM »
Hi Electrical Wizards
     " I took the tank off and dremeled more around the ground connection for the coils thinking maybe it wasn't grounded."
     What is connected here? I see no grounding of the coils in any Honda 4 wiring diagram. Nor is there any connection to the primary or secondary circuit of the coil that is in the house were it is warm.
          TomC
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
Offline bill440cars
« Reply #223 on: February 16, 2007, 06:22:01 PM »
         Hey Doug,
                 Are you talking about the brace that goes on the tubes or the fork legs. (Just in case you aren't familiar with the different kinds) The one on the tubes is for extended forks and the kind that goes on the fork legs can be found in 3 pieces so that you can attach the clamps themselves to the legs and add the center piece to tie it all together. In the case of the 3 piece job, someone here (don't remember who right off) made spacers and added slightly longer bolts to allow for a larger tire size. Maybe someone who knows (or that did it) will chime in here soon. I don't know what to add on the electrical problem Doug, Sorry.
                                                 Later on, Bill :) ;)
Member # 1969
Offline tsflstb
« Reply #224 on: February 16, 2007, 06:47:57 PM »
Probably the least of your concerns right now, but I made some spacers to get a fork brace to clear the tire.  It worked out pretty good.
http://www.sohc4.us/forums/index.php?topic=11142.0
Wish I could help you on the electrical side.  Just be methodical with the volt meter and think like an electron.
