So here's some pics of my old 77 pd41a carbs with out vent nipple or vent tubing, hopefully you can see the casting with the vent hole. Each body has a cast vent hole, I would guess they are early carbs and they switched to the later vent nippple and tubes. Also pics of my wooden rack, the rack attaches through the throttle shaft spring hole and sits in my bench vise. Easy to do the clear tube method or pull bowls and change jets, bench sync.
