The SOHC/4 World Tour is in under way.
That's actually a pretty neat solution for aftermarket headlight clamp use if you don't have the original fork ears as they are getting quite difficult to find now days!John
Gaiters, no caps. The caps were found on 750s.Before you install the gaiters, look to see if they have small weep holes. If so, orient the hole to the "lower side" of the pleat for drainage. And I prefer to align the seam to the rear like a lady's stocking
