Hey everyone, I'm in desperate need for a little advice with a problem I've encountered with my 75 cb750. I can't get it to start even though I have great spark, fuel, and compression. As the starter is spinning, I can hear pops coming out of the exhaust with every turn over like it's trying to start, but no luck.
A little background:
I did a ring job, and installed dyna coils and ignition on the bike when I first got it, and it ran very well directly after that. I went to adjust the valves A few months ago, and I accidentally dropped a screwdriver bit down the cam chain tunnel from the breather cover. So I drained the oil and hoped to find it on the oil pan, Unfortunately not. So I dropped the motor out of the frame a few weeks later and rocked it back and forth and luckily the bit fell right out of the oil pan. I left the oil out of the motor during this time, but kept the motor sealed up. I took the opportunity to paint the the frame, do an allballz bearing conversion and new progressive forks and shocks while the motor was out.
After I put it all back together and ran a new simplified wiring harness, I've encountered this issue. I know the wiring is rock solid, soldered and heat shrinked, no crimp-ons. I have excellent, bright white sparks coming out of all 4 brand new NGK D8EA plugs. I have a freshly rebuilt and cleaned carb, with a small float height issue on #4, but that shouldn't stop it from running.
Wondering if anyone else has encountered a similar issue or has any advice on what I should try next?
Thank you for any and all suggestions.
All mods:
Dyna electronic ignition
Dyna 3ohm coils
Mac 4:2 turnout exhaust
Running the stock airbox
