Author Topic: stiff throttle  (Read 3309 times)
Offline Dakotarider
stiff throttle
« on: August 15, 2017, 07:48:25 pm »
How do I get the throttle return spring to loosen up?   I have a 78 cb750k with the PD carbs.
If one bike is good, three is better!
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: stiff throttle
« Reply #1 on: August 15, 2017, 07:57:30 pm »
take it off and stretch it.  don't ruin it just give it a good stretch.  night and day for me on my 750.
cb750 k6 - ugly
Offline MoMo
  • Ride like you're invisible
Re: stiff throttle
« Reply #2 on: August 15, 2017, 09:32:01 pm »
other things to check:  throttle sleeve dirty, end of grip binding against handlebar, throttle cable binding from grit or improper routing or frayed, slides binding...Larry
Offline Dakotarider
Re: stiff throttle
« Reply #3 on: August 16, 2017, 05:26:55 am »
the spring is the coil type around the slide shaft, how to I stretch that? Everything else is smooth and free.
Re: stiff throttle
« Reply #4 on: August 16, 2017, 05:36:45 am »
Before I work on the spring I would be completely certain that cable is not fraying. This is common as the cables age. You get very tiny breaks in the strands that form "hairs" that scrape the walls of the sheath. These are not large strand breaks. They are numerous. If you lube the cables and everything smooths out, that is probably your problem. The lube is temporary. If you cables are old or original, they should be changed. Having a throttale cable break whicl you are our riding really sucks.
Offline evinrude7
  • not a kung-fu
Re: stiff throttle
« Reply #5 on: August 16, 2017, 06:21:33 am »
ahh good question.  it's different on mine.  can you post a photo?
cb750 k6 - ugly
Offline evinrude7
  • not a kung-fu
Re: stiff throttle
« Reply #6 on: August 16, 2017, 06:30:57 am »
i think i found a photo of it here.  http://forums.sohc4.net/index.php?topic=97319.0 however this is on a 550.  is it like this?  if so can the spring be "let out" a little while still offering "snap back" upon release?
cb750 k6 - ugly
Re: stiff throttle
« Reply #7 on: August 16, 2017, 07:26:56 am »
Offline Dakotarider
Re: stiff throttle
« Reply #8 on: August 16, 2017, 07:31:59 am »
yes that is the type that I have in the picture.  The issue is that there is too much snap back, causing my wrist to tire even on a 20 minute ride.  I have smooth barrel type hand grips causing me to grip harder than I should need to.  I have other bikes and they don't have as much snap back as this bike.  I know I could get different grips to help, but it is still too much snap.  I want less snap.
Re: stiff throttle
« Reply #9 on: August 16, 2017, 07:39:34 am »
Its a safety feature.  You WANT the slides to close like a guillotine.
Get a crampbuster or eat more spinach  ;D
Offline Dakotarider
Re: stiff throttle
« Reply #10 on: August 16, 2017, 09:05:00 am »
 The safest way to ride a bike is to leave it in the garage.   The older I get the more I realize that the joy in riding increases with the comfort level. The difference between riding an old bike and a new bike is the small details that make you feel like one with the machine. Well, the easiest fix is to get better grips.
Offline CycleRanger
  • No comment about being an
Re: stiff throttle
« Reply #11 on: August 16, 2017, 09:38:44 am »
If the stiffness lasts more than four hours call your mechanic.... ;) ::)
But to be serious, larger diameter grips might help.
Offline lrutt
Re: stiff throttle
« Reply #12 on: August 16, 2017, 09:39:33 am »
Has to be in your cable or throttle sleeve. Those springs aren't all that strong.
Be glad you don't have a Guzzi Lemans. Those 2 big Delorto pumpers will make you look like Popeye in no time.
Offline Dakotarider
Re: stiff throttle
« Reply #13 on: August 16, 2017, 11:28:45 am »
I knew there would be some comedic relief soon. ;D
The issue isn't the dynamic actuation of the throttle, twisting.  The issue is the static hold necessary to maintain speed.  Imagine one of those squeeze exercise thingy's, the kind with the hand grip and coil spring.  You could do that all day without taking a break, but wouldn't last long if you had to hold them closed.
I have already made certain that my throttle cable and throttle action is free and without bind.  Those are good.  If they weren't, then the throttle would be more sticky thereby decreasing the amount of grip necessary to maintain speed.  Kind of a built in speed control, twist it to the desired rpm/speed and let go.  I've had throttles like that. :)
I agree that the slides need to snap back into place, I just had a wish that I thought some else might have an easy fix for.
Maybe i just go buy that wrist grip exercise thingy...
Re: stiff throttle
« Reply #14 on: August 16, 2017, 11:33:16 am »
Crampbuster !!!
...or a shakeweight  ;D
Offline Dakotarider
Re: stiff throttle
« Reply #15 on: August 16, 2017, 11:36:51 am »
shakeweight?
You're motorcycling all wrong! ???
Re: stiff throttle
« Reply #16 on: August 16, 2017, 11:44:54 am »
shakeweight?
lmao  ;D
Offline lrutt
Re: stiff throttle
« Reply #17 on: August 16, 2017, 01:19:33 pm »
Get those barrel shaped grand tourismo grips. Look good on vintage bikes and relieve a lot of that stress you mention
Re: stiff throttle
« Reply #18 on: August 16, 2017, 05:49:33 pm »
+1 fat sticky grips you are only resting your hand on it.
Re: stiff throttle
« Reply #19 on: August 16, 2017, 07:51:27 pm »
There are the old barrel shaped design that has the rubber raised grid forming that barrel.  They do a job at isolatjng vibration.  I bought a set from a seller ibuy.isell and they were inexpensive, never used them  i think they are still being sold on ebay.  I currently have a grip which is the Performoance grip Gel grips that are pretty tacky and soft.  I believe that Randakk's sell them as his Ultimate grip or some such...
They are not a huge diameter grip, this is another way to help with that problem...another is to replace the throttle assembly with a quick action throttle that actuates in 100 degrees.
Offline Dakotarider
Re: stiff throttle
« Reply #20 on: August 17, 2017, 05:42:01 am »
Grips it is.    Always a fine line between ridable and and looks.
Offline lrutt
Re: stiff throttle
« Reply #21 on: August 17, 2017, 11:34:49 am »
emgo has the gran tourismo grips. Have those on about a dozen bikes.
Re: stiff throttle
« Reply #22 on: August 17, 2017, 11:34:40 pm »
The name of the grip I described but could not recall the name of is a Bolton Grip.
Similar to a gran tourismo shape in the waffle style  surface.
