Author Topic: What is this piece called?  (Read 2197 times)
Offline Wilskinz
« on: August 23, 2017, 09:19:50 AM »
New to bikes in general, but just bought this 76 cb550k and am buying all new parts but can't seem to find what this part is called. Sprocket retainer? Its the outside disc on the left of the sprocket between the frame and the sprocket with 4 bolts. Also am wondering how this damage could have occurred
« Last Edit: August 23, 2017, 09:25:04 AM by Wilskinz »
Offline minimo
Re: What is this piece called?
« Reply #1 on: August 23, 2017, 09:26:27 AM »
Honda Part: 41211-323-000 Sprocket Side Plate
Offline minimo
« Reply #2 on: August 23, 2017, 09:28:02 AM »
And with some pliers and a soft-blow hammer you can straighten it back out some with decent results (with some sanding and paint).
Offline Wilskinz
« Reply #3 on: August 23, 2017, 09:38:22 AM »
Thank you! Also I've just noticed that the PO has installed an o ring chain ansmd from all I've read on this forum that is a very bad thing. Should I get new sprockets as well as a standard chain and this sprocket plate? Will I have to change anything to make the bike suitable for a standard chain?
« Reply #4 on: August 23, 2017, 10:42:49 AM »
You should also check the front sprocket area for scarred crankcase from the wider oring chain.
« Reply #5 on: August 23, 2017, 11:36:59 AM »
Don't panic. Just check for scars first. Not every O-ring chain is the same, some hit the crankcase, others don't. Also maybe some models are more vulnerable than others. BTW, is your CB550 a K model or an F? I guess it's a K.
« Last Edit: August 23, 2017, 11:43:41 AM by Deltarider »
« Reply #6 on: August 23, 2017, 02:50:38 PM »
Def a K model....
Offline Wilskinz
« Reply #7 on: August 23, 2017, 03:04:27 PM »
Yes, its a k. Seems like googling the part number only brings up sources that are unavailable. Is this a rare part?
« Last Edit: August 23, 2017, 03:06:46 PM by Wilskinz »
« Reply #8 on: August 23, 2017, 03:28:10 PM »
It's NLA from Honda.
Start a thread in the Parts Wanted area, I'm sure someone has an extra...
Offline Wilskinz
« Reply #9 on: August 23, 2017, 03:31:45 PM »
Thanks again everyone! Will make a post now.
Offline przjohn
« Reply #10 on: August 23, 2017, 05:34:49 PM »
You don't need that plate, just replace the sprocket if it is worn.
Offline Rocky2010
  • Live in Strayla
« Reply #11 on: August 24, 2017, 05:14:37 PM »
Look much nicer without that plate :)
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
Offline jonda500
« Reply #12 on: August 26, 2017, 07:37:38 PM »
I am guessing it suffered a chain derailment - my 500 project came with the same damage to the sprocket cover, I straightened it out, but eventually found a used one on fleabay.
John
A starter clutch thread:
Offline jonda500
« Reply #13 on: August 26, 2017, 09:37:11 PM »
You'll most probably find the inside lower part of your left shock got chewed out a little too...
John
Offline Airborne 82nd
« Reply #14 on: August 26, 2017, 10:54:39 PM »
John
Isn't that what it was put there for ;D
Offline jonda500
« Reply #15 on: August 27, 2017, 10:07:22 PM »
I think mainly it's a dust cover for the wheel bearing. It certainly doesn't help much with chain derailment on a 550 (37T sprocket)!
John
