Little 90 is running pretty well...shifting good and easily rockets along at 45mph on flat ground
Just takes a moment to get there!
I'm a little bummed because after it gets really good and warmed up, i've got a tiny bit of exhaust smoke
Doesn't smoke at all at startup, but after 10 minutes of riding I've got a little bit. Just put a brand new spark plug in before this ride. Heres a video of said smoke. I'm kind of worried I nicked the exhaust valve seal or something when I installed the valves and such. I have to admit that the tank has year old gas in it as well.
BTW...the pipe blued really bad the last time I ran it as I had the mixture screw turned way in and it was lean
After turning it off and back on, the smoke pretty much goes away. But i'm sure it would come back if I rev'ed it up.
Here’s the plug after about 15 minutes of riding. Thinking it may still be lean. Might put a slightly larger main in.
