Author Topic: Looking for a person to a Valve job  (Read 1112 times)
Offline gbal06
« on: August 28, 2017, 02:36:36 PM »
Local to temecula ca92584 would be great but open to who the group feels is the best at it! TIA
Re: Looking for a person to a Valve job
« Reply #1 on: August 28, 2017, 02:52:15 PM »
Its basic to bike maintenance.   Learn it and do it yourself.  30 min, tops.
Offline gbal06
« Reply #2 on: August 28, 2017, 02:53:11 PM »
really?  are there instructional videos you recommend?
« Reply #3 on: August 28, 2017, 03:04:59 PM »
I believe Fly is referring to valve adjustments.
If you want a valve job/grind/etc you might want to send/take your head, after you've disassembled the engine, to APE in Rosamond since you are close.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #4 on: August 28, 2017, 03:25:21 PM »
A lap dance... Er, I mean valve lap job, would only be 30 minutes.  I know the valves on a Wing are coated and shouldn't ever be ground.  I can't remember if the same is true of the '70s CBs. But lapping should be OK
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
« Reply #5 on: August 28, 2017, 03:28:46 PM »
The guides need to be checked as well.
Offline gbal06
« Reply #6 on: August 28, 2017, 03:38:06 PM »
do you have his info?
« Reply #7 on: August 28, 2017, 03:41:03 PM »
Talk to Dave Hargreaves at Cerberus Moto in San Diego.  It's a community garage.  You can go down there and work on you bike, ask Dave and other all the questions you need to get it done, and if it requires more extensive work, Dave can take care of it or outsource any necessary machining work.
Offline Keith
« Reply #8 on: August 28, 2017, 06:06:28 PM »
My recommendation is to never consider lapping valves sufficient. Guides must be checked first, and replaced if needed, then reamed to correct clearance. Valve seats need thorough inspection . Only a qualified machine shop can replace damaged or sunken seats. Installed valve height is critical to ensure a long term repair. Stretched valves should be replaced. Seats should be cut to ensure valves seat properly, then valves can be lapped. Each valve is the inspected to see where it contacts the seat, if too close to the edge of the face, the valve will overheat. If satisfactory, coat the valve seats with Prussian blue or similar, and cut the (usually) 60 degree and 30 degree angles to achieve a "three angle valve job." There are specs for the final seat width, with the exhaust seat typically wider than the intake seats in order to help dissipate heat. Skip any of these steps, you are risking doing the job over sooner than you wish.Air cooled engines require far more care than water cooled engines.
« Reply #9 on: August 28, 2017, 06:09:39 PM »
PM member/owner Big Jay here or http://cbrzone.com/sohc.html
Offline Mr. Mike
« Reply #10 on: August 28, 2017, 09:52:27 PM »
gbal06-
Another local for you off the 215 at Ramona Expressway, Perris, CA.
"Classic Honda Restoration"
Dennis Trudelle
951-943-5599
951-323-1873 cell
Good guy, very knowledgeable with SOHC Fours, and fair pricing.
2002 Electra Glide
1978 750K
1966 CL77 (sold)
2020 CB500X
Offline gbal06
« Reply #11 on: August 30, 2017, 05:07:48 PM »
thanks i will look into his garage!
Offline gbal06
« Reply #12 on: August 30, 2017, 05:08:37 PM »
thanks!
