Author Topic: Crack inside crank case!!  (Read 3392 times)
Offline Mike-Quebec
« on: August 23, 2017, 04:13:17 PM »
Hello everyone !!
As I'm freshly new to this forum, I must introduce my Honda project briefly!
I bought a barely functional Honda CB750F 1975, but all parts were there!
A strange noise coming from the engine when running was the start of the project! So, everything was remove from the frame and since I stand next to a pile of parts!
The fork, the brakes, the wheels, the top engine, etc are actually done, the frame with powder coat gloss black, etc...
NOW, I was at my last fight with a stuck bolt, this time in the crank case: penatrating oil, heat, nothing, so I use an bolt extractor.. nothing.. maybe with more force and ''SNAP''.. a crack on the primary shaft holder... @£*$%! ! I contact a professional welder I know and he can't do nothing for this..
What are my options? Here in Quebec from Canada, it's really really hard to have parts! Can I brazed it? Can I use epoxy? I want something strong as everything else!
Thanks for your help! Or watch if I part out my bike!
« Last Edit: August 24, 2017, 09:49:24 AM by Mike-Quebec »
Offline BPellerine
Re: Crack inside crank case!!
« Reply #1 on: August 24, 2017, 05:52:49 AM »
 pics would be nice,crankcases are not hard to find in canada,I live in nova scotia,so dont give up yet.bill
1978 CB 750K ard and webers
another anfob
Offline Mike-Quebec
« Reply #2 on: August 24, 2017, 05:59:11 AM »
Hi Bill !
The pictures are noted ''Attachments awaiting approval'', so I guess they will be available soon!
As for parts, yes I saw time to time parts but they are at a diamond price!! I can't justify buying a used, removed and non functional engine for 500-800$!
Offline enwri
  • So that noise is normal?
« Reply #3 on: August 24, 2017, 06:04:56 AM »
I think it used to be at least 4 posts before attachments would show.
77 CB 750 k.. 29 years and counting.
91 TDM 850 (No.34) so comfy and soft
8? XJ 550 meh...
76 XL 350 Super Sport stump puller..
80 XR 200 idiot proof
75 MX 250 b dangerous
Offline magnum56
« Reply #4 on: August 24, 2017, 06:24:03 AM »
Put a "wanted" post up for a set of 750 cases here on the board.  (you won't want to mix and match upper and lower cases).
http://forums.sohc4.net/index.php/board,182.0.html
However, take full stock of everything else your current engine may still need.
You may find getting an entire "runner" could actually be cost effective.
'74 CB750K
Offline Mike-Quebec
« Reply #5 on: August 24, 2017, 06:33:28 AM »
Calj737,
There is not much bolt left in the hole; I drilled the bolt previously to insert the extractor. What has cracked, is the surrounding of the threaded hole. I hope my pictures will show, that should be more clear.
Offline Mike-Quebec
« Reply #6 on: August 24, 2017, 06:35:57 AM »
Magnum56,
What may be the result by mixing and matching two different engine (top and lower case)? I've already rebuild the top end, the cylinder and piston..
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #7 on: August 24, 2017, 06:55:42 AM »
The case halves are "align bored" at the main bearings. The case halves are a matched set and should never be "co-mingled".
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #8 on: August 24, 2017, 09:23:10 AM »
 Find a shop that does EDM bolt removal, they will get it out, for a few hundred or less.
 They can burn a hex hole into a broken thread, then insert an Allen  wrench and turn it out..
Offline Mike-Quebec
« Reply #9 on: August 24, 2017, 09:43:21 AM »
Ok, I find a way to publish at least two pictures! You can see them upper!
« Reply #10 on: August 24, 2017, 09:52:13 AM »
Sorry to see that, replace the engine or cases.
Offline BPellerine
« Reply #11 on: August 24, 2017, 10:13:07 AM »
look in ontario,or quebec kijiji adds,or post a wanted add,one will come up,other years fit too.bill
another anfob
Offline magnum56
« Reply #12 on: August 24, 2017, 10:32:41 AM »
Yes ... that is BAD ... very BAD.
Do the "wanted" thing on all the various forums for the upper and lower case "halves", and anywhere else you can think of.
The case halves haven't changed much (if any) for any of the 750 K and F versions.
Good luck.
'74 CB750K
« Reply #13 on: August 24, 2017, 11:28:22 AM »
I am trying to imagine some scenario that would cause that, but can't think of one..
What does the other side look like  ? It might  end up being a display motor.
« Reply #14 on: August 24, 2017, 01:16:44 PM »
Cases without drive chain damage
New cases will need new crank bearings. Old bearings must be bad, right?
Nothing to be reused even if new cases with same letters are found.
Time to replace primary chains + tensioner + cam chain + tensioner. Check all ball bearings. Primary hub might need new cush rubbers inside + new needle bearings?
Clutch must be good enough, can be replaced later on with engine mounted and no need to drain oil either.
Time to find another completely refurbished engine?
« Last Edit: August 24, 2017, 01:22:17 PM by PeWe »
« Reply #15 on: August 24, 2017, 03:10:11 PM »
As cheap as motors are, I would just buy another.  And rebuild the top end as necessary...
Offline Mike-Quebec
« Reply #16 on: August 24, 2017, 04:24:36 PM »
754,
The cause of the damage was me and only myself! I over torque the extractor tool, so before the tool snap, the aluminum case was more fragile so it brake... and let me with a very long face.
Offline Mike-Quebec
« Reply #17 on: August 24, 2017, 04:30:46 PM »
To be honest, yes I was at the end of the project but I'm kind of tired of it. Each part I need take at least 1 month to come at my door when bought online. I think I will part out the bike for the happiness of anyone needs parts already rebuild!
Offline przjohn
« Reply #18 on: August 24, 2017, 05:34:00 PM »
And so, another parts bike is born.
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
  • Newcastle Ontario
Communicate
Offline disco
« Reply #21 on: August 25, 2017, 05:44:48 PM »
Another example of why 'Ezy Outs' extractors should be avoided like the plague!
« Last Edit: August 26, 2017, 09:40:21 PM by disco »
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline westhewelder
« Reply #22 on: August 28, 2017, 10:59:40 AM »
Welder here. It's do-able but your going to pay as much so weld and deck that as you will for a full motor. Check manitoba kijiji there's a bike graveyard and the guy will ship stuff.
Sent from my SM-G920W8 using Tapatalk
2011 Kawasaki Vulcan 2011
1969 Honda cb750 (project)
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #23 on: August 29, 2017, 11:32:13 AM »
+1 to that!
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
