yes, the points cam is the advancer unit, and yes the grease rubs off to the points rub blocks each revolution, but a small amount of lubricant/grease/oil is still retained on the surfaces which helps reduce the amount of wear... the felt pad as being part of the points plate is usually soaked in a light oil for the same effect..
