Author Topic: Oil change CB750K0  (Read 607 times)
Offline DickL
  • Really really old
Oil change CB750K0
« on: September 07, 2017, 06:50:57 PM »
Drained the oil tank, removed and installed new filter with new o rings. But the bottom oil plug is really snug. Dont want to take a breaker bar to it. ANy suggestions?
1970 CB750
1999 Honda Valkyrie
Re: Oil change CB750K0
« Reply #1 on: September 08, 2017, 03:30:18 AM »
Use a ratchet with 17mm socket, adjusted to loosen. I have noticed that it is very easy to do it in wrong direction with bolts up side down, tighten instead of loosen. Correct tool no mistakes.
Same with carbs if mounted and float bowl removed removing the needle jets.
Offline DickL
  • Really really old
« Reply #2 on: September 08, 2017, 03:35:42 AM »
Im turning in the correct direction and using a 3/8 inch ratchet with a 17mm socket. Not moving
1970 CB750
1999 Honda Valkyrie
Offline Swoop
« Reply #3 on: September 08, 2017, 04:03:37 AM »
I would use a box end wrench and tap it firmly with a hammer.
« Reply #4 on: September 08, 2017, 04:42:55 AM »
+1-  I use a rubber mallet on a wrench or socket handle. The sharp blow will usually break it loose safely rather then an overpowering constant torque. New sealing washer would be nice to have on hand when you re-install it.
Offline Johnie
« Reply #5 on: September 08, 2017, 07:22:46 AM »
Use a 6 point socket on it. Less chance of slipping.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #6 on: September 08, 2017, 08:43:50 AM »
I prefer 6 point on a breaker bars of flex head.
Often it needs a sharp wrap...I prefer not to do that to ratchets.
Son it was probably over tightened, not sure if a torque spec us listed, but it does not take much.
