Bike got correct brake pedal. Some testing to make it to sit correct. Brake shoes might have been more worn than I thought. I like the old Honda marked shoes that most likely has good old asbestos.
All electric stuff connected and work!
(After some issues and fault tracing thanks to bad blinker relay and dashboard bulbs.)
It should have worked direct without fault tracing if the new Yamiya crappy blinker relay(s) should have worked. Upon that really crappy LED bulbs I installed in the dash board!
All worked for a minute or 2, Oil pressure stopped lit, next neutral. Measure the conductivity and voltage on the headlight bucket connections showed that bulbs must be failing. Same with blinker relay.
Replaced bulbs with old fashion wolfram bulb as the bike expect to get. Working.
Bought a cheap (4€ blinker relay for cars that had same round size as the Yamiya/-Honda rubber mount.
Worked direct!
I did not try other bulbs in the blinkers with more wattage since the blinkers are new Honda blinkers sold by Yamiya so their relay should work. i tried 2!
I saw that the bulbs are all one thread bulb, not as rear light with 2.
Bike should be ready to be started IF only it has a working Oil pump. NO flow at the oil galley despite 1 x 20s + later 1 x 10s pumping with the electrical starter.
I'm really happy to have used Redline assembly lube for crank, cam and other moving parts when assembled the engine. over 1 year ago. Project photos show a big sprocket on kick starter shaft is good news too...It SHOULD work
Next is to remove pipe 3-4 and oil pan. Remove oil pump and prime it really well. I do not drain all oil from oil tank before to see how it will flow with pump away. Maybe use extra thin oil to start up the pump with... It has Motul dino 10W-40 now.
Update: I had to drain pump again in a deep oil bath, releasing the nut on relief valve letting bubbles out. I opened the other 2 bolts keeping the leak stopper valve to vent out a little air too. Made sure that oil could flow in. Pump could now suck better when my thumb blocked one of the 2 holes for oil lines and rotating the sprocket. Same on the other hole rotating in the other direction.
Conclusion: Only drain pump in oil and rotate the sprocket is not enough to get all air out.
My earlier engine reworks with pumps usually cleaned pump with degreaser (naphta), then a little oil. This made the solution thinner and most likely easier for air to get out, never a long running on starter to get oil flow by the pump.
Oil flowed nicely out thru the oil galley that will get an oil pressure gauge to supervise the oil quality/viscosity when hot.
I got the Yamiya relay to work. Important to test where the 2 wires should connect and not. It took a few sec until relay triggerred
