Author Topic: Thoughts about points  (Read 49656 times)
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Thoughts about points
« Reply #100 on: September 18, 2017, 12:50:38 PM »
All I can hear is the wooshing as jokes pass ove rmy head  :-\
Much to learn, Grasshopper. Much to learn-
lucky I enjoy learning and am enthusiastic about the topic!
"This too shall pass"   ;)
Yep, eventually you'll forego the polite manners customary of the northern brethren and pick up a few aussie slurs to hurl around the shop.
AirCanuck
« Reply #101 on: September 18, 2017, 03:34:30 PM »
I'm sure the day will come. So far it has been very interesting.
AirCanuck
« Reply #102 on: September 18, 2017, 03:35:04 PM »
I'm RCAF, work with Aussie exchange pilots all the time so I got that covered :D
« Reply #103 on: September 18, 2017, 09:46:51 PM »
I choosed both, Points AND Electronic ignition. Hondaman module ;)
It got condensors (capacitors) today too. Were delivered with the point plate, NOS TEC
I have used it without most of the time. I have had some minor misfires now and then at higher rpm that might be the result of no condensors.
I checked ignition setting today with dwell meter and strobe lamp. Still spot on since  almost one week back!! I was sure that the setting should go bad when I moved point plate a little counterclockwise and then clockwise from my setting to see if dyno result will change. (It did not like more advance at higher rpm, a little bit later OK, but no big deal.
I'll have to adjust again this winter when I lift cam to re-torque the head just  for sure. Maybe I let another cam play around for a while...
Set ignition is a must for me anyway since I remove the ignition when timing the cam, degree wheel is mounted on the advancer.
Alright guys.  I'm biting the bullet of embarrassment.  What is dwell on this system?
The 'dwell' angle is the amount of time the points are closed in one revolution, measured in degrees.
But, cheap dwell meters will yield different readings from those often published here. If the dwell meter you have in use can first be calibrated to points-closed reading (zeroed) and then run, it will give an actual dwell. Most aren't that good, today, being just pulse-width measurement estimation gadgets. I have on old racing meter which IS accurate, but for the sake of not starting another 'oil thread'-like argument, I won't published what the real dwell numbers are from these bikes. ;)
Instead, set the gap and timing to be spot-on for YOUR bike with YOUR dwell meter, and then remember that value, instead.
Thanks for the input Mark. I have a cheap automotive multimeter where dwell is one of the functions. I'll check the gap the old way to verify. I like the dwell meter when I'll get both points equal, measure when running at around 1200-1400 rpm.
It should be at max gap (~0,4mm) since dwell is 23 degrees at 8 cyl setting.
Edit: Measured the point gaps, they were at max as dwell meter shown with 23 degrees. Maybe a little bit more than 0.4mm on 2:3. I changed to 0.35mm on both the old way with feeler gauge. I'll see what the dwell meter will say about that
« Last Edit: September 19, 2017, 11:25:52 AM by PeWe »
« Reply #106 on: September 19, 2017, 07:31:59 PM »
My old Borg-Warner racing (high performance) dwell meter shows my 750 at 44-46 degrees between 0.012" and 0.014" gap. That's where I usually run mine.
« Reply #107 on: September 19, 2017, 07:39:24 PM »
Anyone remember the A.R.C. Ignition box?
Just saw one on ebay. https://m.ebay.com/itm/1974-79-Honda-CB550-four-CB-550-H253-1-a-r-c-ignition-system-ignitor-/292113340439?hash=item44034fd817%3Am%3AmUrIG-XkR5PcSM4DTHYpyPg&_trkparms=pageci%253A642de65c-9d9f-11e7-82ea-74dbd1801657%257Cparentrq%253A9ccedd5715e0ac8034e160dcfff8dd6c%257Ciid%253A2
These were a dwell extender unit (one of many brands) that increased the closed-dwell time on car ignition systems. They worked like this:
the circuit is an SCR, triggered by a short time-delay circuit, which re-closes the ground side of the coil [some short time] after the points open. This reduces the arcing on teh points, making them last longer. While it is of no real value on the SOHC4 bikes, other than reducing the points arcing, they were of value on the family's grocery-getter with a big 8-cylinder engine because it improved the gas mileage about 10%-20% on average. Toyota incorporated them into their 4-cylinder engines, beginning with the 18RC series (2000 cc), calling them "igniter" boxes to avoid patent infringement problems with other companies of the day. If the box fails, most people only noticed that the points once again begin to burn normally: it was very rare for them to short out and die, as the SCR is about as reliable an electronic part as a 1911 pistol. ;)
« Reply #108 on: September 20, 2017, 01:40:05 AM »
OK, that is the 0.3-0.35mm area.
Minimum gap will load ign coils more, right?
But need to be adjusted when points wear with reduced gap.
I'll see if the bike will run different with slightly less gap.
Offline DickL
  • Really really old
« Reply #109 on: September 21, 2017, 07:03:42 PM »
HEY Mark,
Ill have you know that my two 1911's are very reliable.
DICKL
1970 CB750
1999 Honda Valkyrie
« Reply #110 on: September 24, 2017, 10:49:34 AM »
Checked ignition today
My cheap auto multimeter with dwell function showed 24 degrees at 8 cyl setting. I had set the points to 0.35mm (0.01378") the old way with feeler gauge.
I have had problems at low rpms lately that I have blamed the open exhaust and cam combo.
During ignition setting with strobo lamp: Engine idled really smooth when the 3 point plate screws were loosened, erratic idle when tighten them. I could finally tighten them with OK idle after some attempts where F should align case mark correctly too.
I guess I witness the problem with point plate orientation that some use shims to center the plate properly.
I'm rather sure that this problem can be seen as carb problem and  a throttle synch will not help.
Another project then, add shims for correct plate alignment. If wrong, ignition is not possible to set correctly.
Erratic idle, rattling chains  which feels like typical CB750.... when I know better, typical wrong centered point plate. My point plate is a TEC.
« Reply #111 on: September 24, 2017, 10:58:27 AM »
I see this sometimes, too. When I have seen it, I found that the 'foot' of one of the points sets was hitting the points cam at an angle, so only one corner of the 'foot' was pushing open the points. I fixed it by slightly bending the pivot shaft on the points (had to take them all apart for this, slow process!).
« Reply #112 on: September 24, 2017, 11:06:34 AM »
HEY Mark,
DICKL
For all steel-frame 1911 lovers:
Mine is all-steel: Springfield made mine one for just 18 months or so, and it is a wonder! It's a bushingless bull 3.75" bbl, still holds 3" group at 50 ft offhand. I get my father-in-law to bring out his 1944 MIL version every now and then, so we can compare. Oddly, they hold the same group! I don't know how that can be, but paper tells the story. :)
My next addition will (hopefully) be the ATI 4" with the threaded end.  ;)
If not that, maybe a Baby Rock?
Offline DickL
  • Really really old
« Reply #113 on: September 24, 2017, 11:39:50 AM »
Good video. I like the Hickock ones. Im headed to the range. Taking my Ruger 1911, my Sprinfield Armory Desert Storm Commerative 1911 and a Windham Weaponary AR15.
Your video with Miculek inspired me.
1970 CB750
1999 Honda Valkyrie
Offline Deltarider
« Reply #114 on: September 24, 2017, 11:41:00 AM »
Am I the only one that is shocked to see firearms so openly praised? What culture is that, where you can openly promote deadly weapons and where, on the other hand, if you would upload a vid of people just enjoying wonderful sex, you would be excluded rightaway. Strange, isn't? Think of it.
CB500K2-ED Excel black
« Reply #115 on: September 24, 2017, 12:12:56 PM »
Thanks for your observations Mark, I'll check the points and how they have contact with the cam. I have new  spare TEC points if needed.
Offline Lostboy Steve
« Reply #116 on: September 24, 2017, 12:15:36 PM »
Apples and oranges. If it were a video of a gun shooting someone that would be a little different.
Yeeeeeehaw!
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
« Reply #117 on: September 24, 2017, 01:19:00 PM »
No, not the only one,maybe one of the only that would speak up.........
« Last Edit: September 26, 2017, 06:48:58 AM by Tom in Newcastle......Ontario »
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
« Reply #118 on: September 24, 2017, 01:58:44 PM »
Just install an EI Per and get rid of that mechanical crap. Sure, it might be more expensive than points or fail after 30 or 40 years like Danny's Martek did, but by then you'll be too old to remember how much you paid for it! ;D
Offline Deltarider
« Reply #119 on: September 24, 2017, 02:03:39 PM »
And if it weren’t for all those wild guys with their 1911s and M1s, your butt would be speaking Deutsch  :P
Are you really that old? How can we ever thank you? BTW... I speak Dutch and German and French and English and Spanish. Besides, I wouldn't go that route if I were you. FYI, it's widely acknowledged that the Soviet Union and it's army made the biggest offer by far in WOII: 10.700.000 deads (military) and another 11.900.000 civilians but, hey, that doesn't make a good holywood film, now does it? ;D BTW, did they ever teach you anything on those numbers when you were in highschool? Oh, btw, when the liberation started (finally) my father and grandpa were still encarcerated for their work in the resistance. What do you think, are they excused? Shall we leave it here or do you maybe wanna discuss those wild guys with their 1911s and M1s in 'Nam? I dont know about you but I suggest we leave it here.
« Last Edit: September 24, 2017, 02:22:02 PM by Deltarider »
Offline DickL
  • Really really old
« Reply #120 on: September 24, 2017, 02:35:38 PM »
Deltarider,
Your experience with sohc is greatly appreciated by me and your contributions to this board are immense. HOWEVER, I find your choice of avatars to be offensive as well as the video that you reccommend as being funny. I do not think it is appropriate. Generally, Americans would not think of offending any one from another country. We respect others choices and individualism here. Uour poitics are just that...they are our politics
Dickl
1970 CB750
1999 Honda Valkyrie
« Reply #121 on: September 24, 2017, 02:44:26 PM »
Blessed are the cheese makers! ;D
« Reply #122 on: September 24, 2017, 03:50:18 PM »
Kitchen knives are deadly weapons.  Screwdrivers are deadly weapons.  Hammers are deadly weapons.  Autos are deadly weapons.  Motorcycles are deadly weapons.  A bottle of gas with a wick in it is a deadly weapon.
Mix bleach and ammonia from nearly any grocery store and you have a very deadly weapon.  According to the TSA, box cutters are deadly weapons.
So now we mustn't be allowed to discuss any deadly weapons?  No more freedom of speech?
Guns are tools and nothing more.  Seldom do you need a tool until you do.  Who are you to tell me I don't need one.  What ivory tower do you speak from?
More talk of guns is fine with me.  Education is a good thing, especially when it comes to powerful tools.  The more you know, the safer you can be.  The less you know, well that is just ignorance.  And words from the ignorant are far worse than talk about guns.
A government that does not trust guns in the hands of its citizens is not a government to be trusted.  That is a ruling government placing itself above the rights and needs of it's citizens.
And mealy mouthed nincompoops with emaciating agendas have no right or the intelligence to tell me what I need.  If you think otherwise, there are plenty of places in America that are more interested in exploiting the people than serving their actual needs...like education, for example.  Just move to the areas that have the strictest gun laws and ignore the high crime stats for the area...happily.
What's the old adage?  Keep the people fat dumb and happy and you can rule for eternity.  And misinformation is just another way of keeping the people dumb.
The anti gun agenda is evil in its conclusion.  It only serves to force subservience.
Lynch mobs proved that the majority is not always right.  Similarly vogue for the time.
This country was founded placing individual rights above all else.  Innocent until proven guilty.  Most other counties added selected individual rights as an afterthought.
I tend not to listen to those indoctrinated in countries outside the US.  Your rules and in many cases sensibilites just don't apply here in this culture.  I have no problem with you staying where you are and living under the rules you cherish.  If I thought your ways were better, I'd move there.
I'd rather live here.  Leave me alone with your propaganda.
« Reply #123 on: September 24, 2017, 03:52:18 PM »
So you don't think armed Jews would have had a better chance evading or defending against the ss? That is naive of you.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
  • Holy Cow! I'm a
« Reply #124 on: September 24, 2017, 04:30:39 PM »
Deltarider,
Dickl
Delta and I don't always see things eye to eye.
But I find his choice in avatars to be a rather pointed commentary on the state of the world.
That said, I'm not offended.  Disturbed maybe.  But not offended.
