I have an almost new Dyna-S on the shelf.
Points are a part of the CB750 despite it's not seen until the cover is removed. The points must have got a shock of a kind at last teardown of the engine or later when I shifted advancer, a point or both not properly aligned and need to be adjusted.
An EI might not have survived a similar event ![Wink ;)](http://forums.sohc4.net/Smileys/default/wink.gif)
Yeah mate, points came standard on a CB750, but from memory, you've got a 1000cc engine with a billet block, ported and polished head, bigger valves, heavy duty studs, rods, lightened and balanced crank, heavy duty primary chains, Mikuni carbs, and probably lots more, so why, with all of those other non-original parts fitted, is it important for you to keep bumming around with points?
Your points are giving you problems because they might have received a shock at the last rebuild? Here's a pic of my K2 that I bought back in 2010, Ken, the PO, crashed it at over 60 MPH, destroying the forks, the NOS speedo and tach, ripping open the fuel tank and oil tank, and as you can see, it came down very hard on the points cover. The Dyna S ignition behind that mangled points cover still worked perfectly.............. ![Grin ;D](http://forums.sohc4.net/Smileys/default/grin.gif)
TerrysCanberratrip13Mar20101 by Terry Prendergast, on Flickr
Hi Terry,
1004,725cc (71.25mm pistons), cam too, DP315 with a high overlap that might cause additional adjustments. DP327 cam in and an RC sidewinder exhaust on and I'ts ready for the strip!
The CR might be too low though, only 10.5:1. Dilute the fuel with nitro might compensate...
Threads like this makes this forum really fun! Different tech talk and ideas based on hundreds of years in combined experiences of bad and good.
I believe that the points can work as good as Dyna-S ignition and be more robust (no electronics that might not withstand overcharging that happen during a few minutes now and then).
I have Dyna 5 ohm coils on the bike that must be an upgrade compared with stock.
I can test the Dyna-S to compare but has not time now since I have OK ignition and dyno time soon.
It is a challenge for me to make the bike to run perfect with points as I'm sure it will ![Smiley :)](http://forums.sohc4.net/Smileys/default/smiley.gif)
I can replace the TEC condensors with other capacitors of correct value, smaller size.
I have mostly had carb jetting work behind. I have done dyno times this year to find the correct tuning and has found most of the settings for street and cruising speed. Carbs had no recommendations and I had to change all, pilots, needles and mains. Important to find correct order of the jetting to avoid change again.
I'll check again on Wednesday this week to verify the last correction of float setting on carb 1-2 that caused lean at WOT. Full power and A/F ratio measured in each exhaust with no baffles/diffusers. I balanced the carbs wrong earlier, all 4 at same clear tube setting. These carbs seems to work different so I change back the adjustment I did earlier causing lean on carb 1,2.
Then another hp/torque run with baffles/diffusers in since this will be the setup I'll use which work rather fine right now.
I understand racing guys that use Dyna 2000 with adjustable advance curves.
Maxi dwell might be something since it will most likely work fine with Hondaman ignition module.
*** More Point Hi-Tec *****
I checked the points today to verify Hondaman's observation of how the points bakelite fot contact cam on adv unit. Must be parallel and not bent point hitting the cam with the corner of the fot first. Both points operated correctly when I exercised them manually, contact to cam parallel and electrical contact points looked correct too. Not like old cheap points almost hitting sideways.
The point plate however, is in the good position since last ign setting.
I'll check that the advancer unit has no dirt between the unit and crank and that the point plate is clean with smooth surface where it has contact with cases which must be good too.
These last checkpoints must be valid for a Dyna-S too, right? How it is centered is not that sensitive as for a Point plate?
I have to find the old thread were TwoTired described the importance of a properly centered point plate, shims might be needed.
