Author Topic: Dyna S timing question on CB550  (Read 651 times)
Offline The Machine
« on: September 17, 2017, 09:27:21 AM »
I've timed it with a timing gun, set it at the F mark. When I rev the motor it stays revved for a little bit then slowly comes back down to idle. I know there can be many reasons for this but what would be the most obvious reason? I'll start with that and work my way through the list. Bike runs well, has power but sputters a little at 3/4 throttle.
Offline Scott S
Re: Dyna S timing question on CB550
« Reply #1 on: September 17, 2017, 10:17:19 AM »
 Did you set it at idle or at ~2,500 RPM? I always set the advance for full advance, the II marks just past the F mark. I let idle timing fall where it may.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Bodi
« Reply #2 on: September 17, 2017, 01:38:57 PM »
Most likely is a vacuum leak at the carb spacers.
Offline The Machine
« Reply #3 on: September 17, 2017, 06:19:54 PM »
Thank you, I set it at the advance setting seems to be doing a little better. I'll check for the leak, I've removed the carbs recently so hopefully that's the case.
