Author Topic: Silver paint for crank cases  (Read 5771 times)
slarty-bart-farst
« on: December 28, 2006, 03:02:28 PM »
I have sprayed 10 + sets of crankcases using the aerosol tin made by Holts and available in the UK called " Simonise 5 Wheels" check out the link:-
http://www.holtsauto.com/hints/index.html
One tin does a set of cases, no special prep needed, it does not react with other paints.  It never goes off color due to petrol ( its designed to withstand brake dust + heat ).
Best preperation is wire brush/400 grit wet and dry then warm the cases to 40 deg. Put the spray tin in warm water for 15 mins. Blow off any water round spray nozzel before use.
Its so good you can degrease an engine, warm it up mask it and spary in situe.
Oh update 12/04/07 just found out they make 2 colours now, it's obvious which is which (I just sprayed a top crankcase in one tin switched to another tin for the botton case and found out) there is a darker one as well. Get the light one for Honda cases and the dark one matches late Yamaha.
« Last Edit: April 13, 2007, 01:35:40 AM by slarty-bart-farst »
Offline pae
    • Phil Edwards CB650 pages
Re: Silver paint for crank cases
« Reply #1 on: April 08, 2007, 12:15:56 PM »
I can vouch for this. Did (most) of mine today, goes on really well. Good colour too.
regards, Phil
« Last Edit: April 08, 2007, 12:18:15 PM by pae »
'79 CB650  .... | ....  XJ600 electric drag racer  .... | ....  T W M C
It takes a lot of practice to sound like yourself
Offline Gin Rickey
  • '73 CB350F
« Reply #2 on: September 07, 2007, 08:57:35 AM »
Rookie question, is there a "better" preferred non-chemical way to get all previous engine paint off?
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #3 on: September 07, 2007, 04:56:56 PM »
I prefer not to take off all the old paint. It make a good primer. Just get it down to a clean, tight surface. Paint sticks better than painting a raw surface.
Fonda Honda
Offline m00ntan
« Reply #4 on: September 08, 2007, 01:04:49 PM »
pae, What's that stuck in the manifold?
CB750K4
CB550K1
CM400C
