Been quiet for a while simply because the lathe let me tackle a ton of suspension related stuff that was just waiting to be done.
1. bought a set of bitubos and they feel just great. removed the springs and their claim that there is a separator piston between oil and gas seems true. all emulsion shocks will have these "bubbly" noises when stroking them, the bitubos really felt like it's only oil passing through the orifices. and same weight as the agricultural konis i raced with till now.
2. Bitubo stock shock bushings just wouldnt work with my CB500 top mount/KZ650 bottom mounts, so to redo them all new in nylon.
3. Turned a swingarm chain protector for the left side, and a nylon spacer for the right.
4. the kawasaki swingarm pivot has a 2mm bigger ID, so turned some 1mm thin walled sleeves, a good test of precision for any lathe...
5. this year we are allowed 38mm forks, so upgraded from the heavy stock 35mm to a 38 set off a kawasaki. each complete fork leg is lighter by 3 pounds and the bonus of teflon lined slide bearings instead of steel on ally...
6. used the occasion for a major hydraulics update fitting CBR damping cartridges, required quite bit of spacers to be designed and turned so the hydraulics can work properly.
7. had an all alloy kawaski triple clamp set from another projects sitting around (-1.5 pounds), it was meant for a 41mm, so X4 41/38 sleeves turned
8. kawasaki and honda steering stem bearings differ in ID, so another set of turned adapters, the top one having 0.5mm wall thickness
Things are getting ready to put the cycle part back together, so it'll start looking like a bike again soon
