Author Topic: !974 CB550 Electrical System  (Read 1853 times)
Offline Funkyrabbi
« on: October 02, 2017, 07:31:00 PM »
I have a 1974 CB550 that I am wanting to rebuild the Electrical system on. The current electronics that are on the bike are the original parts. They are chewed up and the coatings are starting to fall off. I am wanting to Switch to an LED Headlight and some sort of small simple LED Tail light. I don;t have any other electrical items on the bike. I am wanting too possibly add turn signals as well. So I would like a good solid list and possibly some links to whatever you guys can suggest. I would also like to find a small simple one button starter if at all possible. Thanks for any and all help.
Offline b1jackson
Re: !974 CB550 Electrical System
« Reply #1 on: October 03, 2017, 03:56:15 AM »
4 into 1 sells a complete harness for around $125.  If you want plug and play, I'd check them out.
4into1.com
Old Honda Rescue Centre
ohrc_vintagemoto on Instagram
Offline nuwonder
« Reply #2 on: October 03, 2017, 04:14:47 AM »
Nice summary from calj737 :)
IF you wanna make a new wiring harness instead of original one, check this link. It's super simple and I think anyone with little understanding how bike wiring works is capable of following these instructions: http://www.bikeexif.com/motorcycle-wiring
Offline Funkyrabbi
« Reply #3 on: October 03, 2017, 05:16:53 AM »
Calj737 my job is custom. I am only running headlight, taillight, and possibly blinkers. What electronic components do I need. I have seen a Voltage rectifier/regulator. At the moment I have all of the original parts. So I am wanting to get a complete working system with the minimum parts necessary. I am willing to build my own minimal harness. Thanks for any help.
Sent from my SM-G930V using Tapatalk
Offline Bodi
« Reply #4 on: October 03, 2017, 07:16:48 AM »
I think legally you need headlight, tailight, and horn... maybe signals if the model year had them?
So not much wiring. A battery, fuse, keyswitch, wires from there to the regulator and ignition coils, and also to the lighting switches and horn switch. Plus to the horn and lights of course. Add a flasher and the extra wire for signals if you have them.
Charging is rather simple as well. Alternator wires to the reg/rect - one field wire gets grounded - and a wire to the battery +, as well ass the wire from the key switch.
There's a comic-book style wiring diagram for a minimal chopper harness that uses all the stock parts.
Offline nuwonder
« Reply #5 on: October 03, 2017, 07:19:50 AM »
Oh and put a neat on/off switch to the power wire which goes to coils, so you can have a kill if you feel you need one. Sometimes just a ignition key off -kill is enough but I always feel like it's nice to have extra kill for the coils.
Offline Funkyrabbi
« Reply #6 on: October 03, 2017, 07:43:48 AM »
Bodi California doesn't require HORN so I am good there. I am wanting to know what electrical parts I need to buy. Such a rectifier/regulator, fuse block, is there anything I am missing. My bike now has a bunch of stuff for the wiring system that I don't know if it's neccasry. I will take a picture when I get home and update.
Offline CycleRanger
  • No comment about being an
« Reply #7 on: October 03, 2017, 08:08:42 AM »
4into1.com
Way cheaper than that.  $80
http://4into1.com/main-wiring-harness-32100-374-000-honda-cb550k-1974-1975/
Offline przjohn
« Reply #8 on: October 03, 2017, 10:56:35 AM »
Another vote for using a reproduction stock harness. You are going to use just about everything if you want signals and brake lights. The harness also connects ignition components and charging system components. I have made my own harness using Vintage Connections components but it is not worth the effort for what you can buy a reproduction for. Just don't use what you don't want to, like the horn.
Offline Funkyrabbi
« Reply #9 on: October 03, 2017, 11:50:47 AM »
Przjohn thanks for the info I never though of it like that.
Offline Funkyrabbi
« Reply #10 on: October 07, 2017, 09:40:01 AM »
What electronic components am I going to need? I want to replace all of the components.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #11 on: October 07, 2017, 10:48:47 AM »
http://manuals.sohc4.net/cb500/service_manual/HSM500550_4.pdf
cb750 k6 - ugly
Offline Gene
  • Chat enuf you too can be a
« Reply #12 on: October 07, 2017, 11:31:27 AM »
4into1.com
no sh*t . . . wow. And here I cleaned my original up.  :D
*1973 CB750K3 (Bow)
Offline CycleRanger
Re: 1974 CB550 Electrical System
« Reply #13 on: October 07, 2017, 11:46:15 AM »
The plugs were shot and the wiring was crunchy on my 550 harness.
Not worth my time to repair just to have issues later.
I got one of these, good harness, exact fit. No issues.
Offline Gene
« Reply #14 on: October 07, 2017, 11:48:29 AM »
This is excellent information. Thank you.
*1973 CB750K3 (Bow)
