Author Topic: Dual outlet petcock for '77-78 550K tank  (Read 1223 times)
Offline Scott S
« on: October 08, 2017, 06:59:56 AM »
 Probably going to be using a '77-78 K model tank on my next project. Normally, it has a single outlet petcock that is 16 x 1.5 mm. I have the earlier dual inlet carbs.
 Any reason I can't use one of these CB350 twin petcocks with the dual outlet? Know of any clearance issues? That would keep me from having to use a T fitting.
 Know of any other low profile dual outlet 16 x 1.5 petcocks?
http://4into1.com/reproduction-fuel-valve-petcock-16mm-x-1-5mm-16950-292-000-honda-cl175-cb350-cb360t-cb450-cl450/
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline mj1176
Re: Dual outlet petcock for '77-78 550K tank
« Reply #1 on: October 08, 2017, 07:16:34 AM »
Pingel definitely has a couple dual outlet options that can be considered low-profile, and they'll make it in whatever thread diameter you want.
Offline Scott S
« Reply #2 on: October 08, 2017, 07:42:28 AM »
 Yeah, the more I think about it, those CB350 twin petcocks hang pretty low. Probably interfere with the head on a 550.
'71 CB500 K0
'81 Yamaha XS650
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: October 08, 2017, 07:56:45 AM »
Is the thread pattern on the 77-78 K different than the 75-77 F which uses the same basic tank? My '75F has dual outputs.
Offline Scott S
« Reply #4 on: October 08, 2017, 09:33:05 AM »
 I'm not 100% positive, but I think it is. I think the thread is different.
'71 CB500 K0
'81 Yamaha XS650
« Reply #5 on: October 08, 2017, 12:49:23 PM »
77-78 CB tanks have a smaller bung than 75-76 tanks.  Something like 5/8 rather than 3/4, or a metric equivalent.  Prior CB Four models (72-74) in the US has the two screw fittings, and a sediment bowl.
I could not find a pingle solution for the 77-78 types.  I did find a CX500 tank valve that fit the 77-78 tanks.
I don't know why you are avoiding the T fitting.  The 77 CB550F came with that set up in stock form.  Works fine.
Offline Scott S
« Reply #6 on: October 08, 2017, 01:35:33 PM »
 That's probably what I'll end up doing.
'71 CB500 K0
'81 Yamaha XS650
Offline jonda500
« Reply #7 on: October 10, 2017, 05:28:42 PM »
The dual output petcock used on many early Honda twins fits the 77/78 550K tank and doesn't fowl anything -  achieving a downhill run with the fuel lines may be difficult though. I subsequently found an 'F" tank so I never ran it like this...
John
A starter clutch thread:
« Reply #8 on: October 10, 2017, 07:55:00 PM »
 I thinkntge thread sizesxare 16mm  and 19mm.  19 is the one you cant adapt to a Pingle  . I did make a few adaptors, wish I had one for my 1975 tanks.
