Thanks for the detailed reply Hondaman.
The carb rubber hoses are new and it has a std airbox fitted with new filter. Std DS replacement 4 it 4's also fitted.
So current position is somewhat frustrating and confusing. Hence the desire to fit some next size up, #42. pilot jets as it would at least help identify if it is a pilot circuit issue?
Are you able to advise with my original question as to if you can use the N424-24 jets which are 32mm long compared to the std 28mm ones which are seeming unavailable in the UK?
Ah, a clue: did you buy the hoses from Honda (OEM)? If so, they are undersized on their OD, which causes them to leak vacuum even when the clamps are fully screwed tight. I had this happen on 3 engines now (one was my own!) that used new Honda hoses since 2013. I switched to using the Oetiker clamps at the head side for that reason. The clamps seem to just barely fit at the carb side, but their spigot is slightly larger OD as compared to the head side.
There's no trouble running with LONGER pilot jets, but there is one caveat: the stock ones are set to the same length (bowl depth) as the mainjet, with the hope that when you run out of gas (before reserve) they both run out at the same time. Most of these carbs actually run out on the mainjets first, the pilots slightly later: when you're running on the hiway, this provides a few moments of reduced power between full speed and maybe 30 MPH before it quits altogether. With longer jets, it will run longer at the lower speed, but for the length difference, there shouldn't be much other change.
There are some differences between, for example, Mikuni and Keihin jets: the entry angle (on the bowl side) is different between them, and the fluid metering hole itself is a different length. This slightly changes the metering: if you take a Mikuni #100 jet and put it in the mainjet of this Kehin carb, in place of a Keihin #100 jet, the Mikuni runs about 5%-7% leaner, approximating a #93 or #95 jet. This is due to those differences, so maybe keep that in mind while tinkering? We see this happen with the aftermarket jets in some of the carb kits we are getting these days: the entry angle is shallower than the ones from Keihin. This makes them run leaner by a little bit.
