Author Topic: 78 550K build - First Post - Couple of questions  (Read 1007 times)
Offline DiscoDave
« on: October 16, 2017, 10:49:06 AM »
I apologize in advance.  I know "Search is your Friend", but I can't seem to generate any results other than no results found...  I've been riding almost 50 years, and I'm experienced on other forums (current other bikes are Valkyries (3+) and F800GS).  What am I doing wrong???
Anyway, first questions are:
1. Tubeless wheel swap - Doable?  Worth the effort?  Thinking CBR600F2 or F3.
2. Related, rear disc - Doable?  Worth the effort?
3. Front suspension swap - Forks only?  Forks plus steering head?  Is there a direct swap?
Thanks!
Offline calj737
  • I refuse...
Re: 78 550K build - First Post - Couple of questions
« Reply #1 on: October 16, 2017, 11:48:11 AM »
The embedded search isn’t working. Use Google, and the domain “forums.sohc4.net” to isolate the search terms only to this forum.
Yes
Yes
Yes
You can do a full front end swap using All Balls conversion bearings, but will encounter a geometry change due to offset. Custom shop, CognitoMoto makes triples and front spoke hubs for modern front end swaps if you prefer, but you’ll run tubes. They also offer a drum-disc conversion hub for rear if you’d rather maintain vintage aesthetics but more modern braking.
Offline DiscoDave
« Reply #2 on: October 18, 2017, 09:05:23 AM »
Thanks for the answers and clearing up the search question!
Not very interested in tubes or vintage aesthetics for this one.
