Author Topic: So much for my electric bill  (Read 1068 times)
Offline eigenvector
« on: October 22, 2017, 10:28:51 AM »
Dang!
We had a big rainstorm last night and my sump pit did what it's supposed to do.
After I came back from work this morning I discovered that the sump PUMP did not.  I don't know the whole story but when I checked on it, the water in the pit was hot - yes, HOT and the pump was jammed.  So potentially I've had the pump jammed for 12 hours.  I have to tear the whole thing apart and figure out why it's jamming - but I'm dreading that electric bill that's coming my way.
Fortunately I'm rarely home so my bill is pretty small anyway - but this won't help any.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
    • http://forums.sohc4.net/index.php?PHPSESSID=mn95mjb9gg9em3g1vtefsbf502&/topic,60973.0.html
Re: So much for my electric bill
« Reply #1 on: October 22, 2017, 10:40:39 AM »
the pump can only use the watt it are ratet for..so dont think it that badd..vorse if they run dry,,then the vindings do not get cooled..and it blow up..
« Last Edit: October 22, 2017, 11:46:21 AM by strynboen »
Offline eigenvector
« Reply #2 on: October 22, 2017, 10:49:34 AM »
I think something crawled up the outlet pipe and made a home in the backflow valve - my own fault, I haven't been very good keeping the plumbing covered.
I have to tackle that job before the next rain storm moves into the area.
Rob
1977 CB550K
1983 VF750S Sabre
Offline Kevin D
  • SE Michigan
« Reply #3 on: October 22, 2017, 12:15:06 PM »
It didn't blow the 15?a breaker, so it will be something less than:
 15a x 120v x 12hr x $0.15?/kWh = $3.24
________________
          1000
Think I'd be shopping for a new pump.
How many dollars is that pump protecting?
Lucky you, it didn't flood with a heavy rain and a dead pump.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline eigenvector
« Reply #4 on: October 22, 2017, 01:03:12 PM »
Well I took a look at it, pulled it apart.
Whew!  Swampy.
Looks like it had hydrolocked, the weep hole was blocked.  I drilled it out to clear it, but I'm going to re-route some of the pipe, plus relocate the check-valve a little higher.
Rob
1977 CB550K
1983 VF750S Sabre
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #5 on: October 22, 2017, 01:45:20 PM »
Lucky you caught it during a break in the weather!
« Reply #6 on: October 23, 2017, 01:29:01 AM »
they cant realy hydrolock..the vheel just run..and make the vater sirkulate..and heat up..if the pumphveel stands still ..it often stone or dead rats.or rope..in there..thek the oil ..there is a oil lubed keramic teighting before the engine..in a oil thamber.(.anyvay on all expensive prof pumps)..id there is gray oil there is vater going in..from the auter sealing..a bit gray is ok..but massive glue in there the auter seal must be thanged...
(im been 10 years in a elektro motor/pump shop)
