I have and had good service from Yuasa Smartshot chargers. They have 5 stage algorithms, as well as float charge. One model is a 1.5 Amp and has a weekly re-evaluation cycle to keep the battery in peak charge.
I see they have a newer product line out now that are intended to maintain AGM batteries. They work fine for flooded types, too.
I wouldn't hesitate to get one of these if I needed another at this time.
But, I have 5 or 6 chargers already with most of them automatic. So, probably won't need any more of them.
I have a dumb 6 amp charger from 1964 intended for bigger car batteries. Yes, I have used it on the small motorcycle batteries, too. But, you have to monitor the battery voltage carefully and constantly, so as not to overcharge and damage it. I never use it peak charge a battery. But, will use to about 80% of capacity if I need it in short time. Once it gets to 14.5V, it's done with charging, for sure.
P.S. Here is a Yuasa technical manual that I downloaded a while back. Some good info despite the sale pitch bent.
