That holds the speedo cable.
Appreciate the info as always Stev-o. No new pictures to post, but a general update. Spent some time over the Thanksgiving holiday working on the CB. Completed both forks seals, added some 15w fork oil, and got them installed back on the bike (Sorry Stev-O, still haven't polished them
Green ScotchBrite pads work really well on cleaning the aluminum cast parts. That seal groove needs to be spotless
Thanks for the tip Cal. I cleaned the front brake caliper with a ScotchBrite pad and replaced the piston and seal (after getting that channel
spotless). Re-plumbed the brake system with some new upper and lower hoses and replaced the hydraulic brake switch. With everything back together, I did run in to some leaks once I loaded the system up with brake fluid; but I addressed all of them and the front brake is now bled and firm.
Next up was replacing my ignition/engine kill switch assembly and throttle cables. The ignition-engine kill switch that came with the bike was devoid of an actual ignition button. Someone had jerry-rigged what basically looked like a doorbell into the wiring to act as the ignition switch. I tried to locate a replacement, but Honda part 35130-377-670 are few and far between and about $100+ when available. I did read that part 35130-377-670 was superseded by part 35130-377-P00 and
should work for a 75 CB550F (
https://zoomdune.com/always-on-always-a-problem-honda-starter-button-woes/). The cables were well worn and exposing the metal housing in some places where the plastic had worn through or been damaged.
I found a NOS ignition/engine kill switch on eBay for $40 and rolled the dice (part #35130-377-P00). Everything was going well until I went to install the push throttle cable. The lower housing on the 35130-377-P00 is ever so different in that the mold allows the head of the push cable housing a few extra mm of insertion. As a result, the nut that is supposed to cinch up the cable housing to the lower half of the ignition/engine kill switch assembly, fails to do so. Now, both of my cables are taught and not slipping off of the linkage on the carbs, but if you roll the throttle forward, the push cable exerts pressure against the inside of the housing and it pops the "L" shaped bend in the bottom of the ignition/engine kill switch out a couple mm. Rolling the throttle on, sucks that "L" shaped bend back up into the lower portion of the ignition/kill-switch housing.
I'm sure a picture would be worth a 1,000 words here, as I'm likely not explaining this well; but aside from a little tick and the housing moving about a couple mm, the cables are secure and the throttle seems otherwise unimpeded. I may wrap a couple loops of some wire around the push cable housing and re-cinch down that nut in hopes it takes up the extra slack.
I suppose the old adage is appropriate here...."buy once, cry once"
