Author Topic: Is this a 550 wheel?  (Read 1121 times)
Online Scott S
« on: November 04, 2017, 04:08:24 AM »
 I picked up this wheel as part of the latest haul. I thought it was a 550 wheel, but something about it just looks different. The brake backing plate seems larger/flatter than the early 500/550 style, but not the same as the later K bike style.
 It has a 37T sprocket, which indicates 550. I'm not good at knowing where/how to measure rim width, and there are no stampings in the rim to indicate size.
 Is this a 550 or 750 wheel?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Re: Is this a 550 wheel?
« Reply #1 on: November 04, 2017, 08:58:33 AM »
It is not 750, brake plate is a totally different looking casting, plus sprocket side is very different.  37 tooth would be nearly un-rideable on a 750 as stock is 48.  Maybe 350/400? cb450? would be very impressive.
« Reply #2 on: November 04, 2017, 01:57:52 PM »
I think the 500 and first gen 550 rear hub had four ribs,the later 550 the ribs were different and used a narrower axle spacer,also the brake plates don't swap into the different ones?ill try and dig up a photo of the later 550 type,can only find the early type.
Offline jlh3rd
« Reply #3 on: November 05, 2017, 05:08:10 AM »
I don’t see a brake wear indicator, I know it’s on a 550 f....was it on the k ‘s ?
    • http://forums.sohc4.net/index.php?PHPSESSID=ac123e75e72u58g0pmtghq37i0&/topic,60973.0.html
« Reply #4 on: November 05, 2017, 11:13:03 AM »
the indikator is just a bend metal arrov..so can easy be left aut...its absolut not a 400 four..it have thet big Lock ring hold the spoke on
Offline jlh3rd
« Reply #5 on: November 05, 2017, 03:47:18 PM »
No, it is not a metal arrow...it is an indentation on the actuating lever, red, reddish orange paint in the indentation with a corresponding mark on the shaft support boss... also painted....
And I don’t see it...
...where do people come up with this stuff...
« Last Edit: November 05, 2017, 03:55:51 PM by jlh3rd »
Offline jlh3rd
« Reply #6 on: November 05, 2017, 04:18:02 PM »
Actually, the mark is on what’s called the brake plate...
Online Scott S
« Reply #7 on: November 05, 2017, 04:29:02 PM »
 Some of them had a metal arrow.
'71 CB500 K0
'81 Yamaha XS650
Offline jlh3rd
« Reply #8 on: November 05, 2017, 05:02:16 PM »
No, they didn’t...not the 550.....the 77 had this, still an arrow indentation, not a metal arrow......not painted....
« Last Edit: November 05, 2017, 05:06:08 PM by jlh3rd »
Offline jlh3rd
« Reply #9 on: November 05, 2017, 05:07:21 PM »
And certainly not easily left off...
« Reply #10 on: November 06, 2017, 05:02:20 AM »
is it a cb 500 t twin..hveel..they used nearly the same as 550..(is there a Lock ring under the metal plate..to hold the spoke in place
