Author Topic: Fastening motor ('77 CB550F)  (Read 2919 times)
Offline GardenGnome
  • 1977 CB550F
« on: November 04, 2017, 04:05:09 PM »
I am wondering where to start in fastening the motor by myself. Last time I had an extra set of hands. I'm finding it extremely difficult to get bolts lined up and keeping the motor and frame from moving around. What have you found works best on where to start by fastening?
If I've learned anything about building a motorcycle, it's check and re-check your work before you put it all back together. Although you do gain more experience by doing it twice.
Offline uksparky
  • Track days
Re: Fastening motor ('77 CB550F)
« Reply #1 on: November 04, 2017, 04:26:44 PM »
On center  stand ...With the motor in the frame use plywood and floor jack under oil pan....start with the front brackets first, dont tighten...then the bottom and rear, use jack to line up...best use a 1/4 x 24" round bar to line rear hole up, then tap bolt through from other side
Present bike 1982 900C Custom
« Reply #2 on: November 04, 2017, 05:27:36 PM »
Is the frame bare?
Put engine on it's side, padded, and place frame onto it.
With the forks and rear wheel off.  The frame is lighter than the engine.
Offline GardenGnome
  • 1977 CB550F
« Reply #3 on: November 04, 2017, 05:45:46 PM »
Yes the frame is bare. I recently installed the swing arm,which was out the first time I installed the motor. Now I'm just ha in trouble getting stuff to line up and stay lined up.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #4 on: November 04, 2017, 06:49:44 PM »
Motor on the floor is legit.  Entry is simple from the right hand (points) side of the machine.
« Reply #5 on: November 04, 2017, 07:30:27 PM »
I just lift them in from the right hand side,i have the sump and oil filter off,starter motor off,alternator off and the breather cover off,start by getting one rear bolt in.
Offline GardenGnome
  • 1977 CB550F
« Reply #6 on: November 04, 2017, 10:24:46 PM »
I will try getting a rear bolt through first. My first thought was to get the front two hangers attached first, but I was finding that task challenging due to the frame moving around so much with the motor and frame on their sides. There's always tomorrow.
« Reply #7 on: November 05, 2017, 01:38:59 AM »
Block up the motor on its side with blocks of wood and pad between it and your blocks with a heavy blanket or cloth and foam pads. Taping the frame rails with masking tape to lessen the risk of chipping your paint as you install is a good idea.
Once it is blocked up to be in the right orientation you can more easily fit the frame. A ratcheting strap from the ceiling and hook into a floor joist can work pretty nicely as well.
Just think through it and approach it logically and it will come together.  Just don't get frustrated and start throwing things or damage something from your frustration.  A buddy or even a female can assist making the job much easier.  Heck some women do anything we do and yes, sometimes they are more creative in thinking about how to do something easier.
David
« Reply #8 on: November 05, 2017, 01:02:56 AM »
A FEMALE?man RAF!anytime ive asked my wife to hold something its always been a tantrum!let alone ask her to help me with the bike!
Offline GardenGnome
  • 1977 CB550F
« Reply #9 on: November 05, 2017, 11:47:28 AM »
Well motor is in. Used the advice of blocking the motor and fastening the rear first. Worked great, scratched the #$%* outta the frame, but that's a cosmetic fix that I can deal with later. Really happy that I'm this far. Let me pose this question though, what should be next? Wheels on, electrical, what would be the next stwp here?
Online Stev-o
« Reply #10 on: November 05, 2017, 12:13:24 PM »
Touch up the frame paint!
Offline jukku
  • Happy with my Hondamatic
« Reply #11 on: November 05, 2017, 12:27:08 PM »
If possible use a C-hook.
Somewhere on the forum there are good pics how to use the C-hook.
Offline jukku
« Reply #12 on: November 05, 2017, 12:51:11 PM »
A hook in the ceiling, a chain hoist, a C-hook and two hands!
Offline jukku
« Reply #13 on: November 05, 2017, 12:54:54 PM »
One version of C-hook
Offline GardenGnome
  • 1977 CB550F
« Reply #14 on: November 05, 2017, 01:27:55 PM »
Front end. Then rear. Then hang the wiring harness.
Calj737 you'll love this I'm sure, but I'm going to be using the M-Unit to do my wiring. But good to know about front end and rear first.
Offline GardenGnome
  • 1977 CB550F
« Reply #15 on: November 05, 2017, 01:29:56 PM »
I thought about this, but it's probably too cold for doing any kind of touch up paint right now, I thought I'd wait until warmer weather or until I get a heater for the garage. But yes, I would like to get after it as soon as I can  :)
Offline GardenGnome
  • 1977 CB550F
« Reply #16 on: November 05, 2017, 01:30:59 PM »
I'll have to try this for my 750 build. Thanks jukku!
Offline GardenGnome
  • 1977 CB550F
« Reply #17 on: November 05, 2017, 05:32:19 PM »
Calj737 what is this frame kit? Is it a mod for the frame to make the removal and reinstall easier for the motor?
Offline GardenGnome
  • 1977 CB550F
« Reply #18 on: November 05, 2017, 06:11:13 PM »
Well that sounds pretty dang cool. I want to find out where to buy one, but I need tho focus on one project at a time haha.
Online Stev-o
« Reply #19 on: November 06, 2017, 06:17:41 AM »
For 750 frames, yes. It cuts sections out of the two parallel tubesand replaces them with a removable set of tubes that either bolt into welded or non-welded receivers. Makes removal, installation and servicing of the motor much easier and service while in the frame possible.
Cal - I have not seen Gordons [welding required] frame kit for sale recently
Offline GardenGnome
  • 1977 CB550F
« Reply #20 on: November 06, 2017, 07:26:12 PM »
Has anyone tried the frame kit from RRR Tool Solutions? I watched a video on their 750 frame kit and it seems like a useful product.
Online Stev-o
« Reply #21 on: November 07, 2017, 06:37:34 AM »
... if not, get Franks.
Have not seen Frank's for sale lately.  Testing your Google skills Cal!
Online Stev-o
« Reply #22 on: November 07, 2017, 06:51:51 AM »
My google is strong, Stevie  ;D
Oh, I know it is!  But since Frank moved, he's been out of machining mode. I'd like one of his on the shelf for a future project.
