Thanks for that really informative update David.... I am going to get a new set of pads (thanks for the recommendation re the EBC ones). The bubbles seem to have lessened in number over the last couple of days so hopefully it’s just a case of being patient and letting them work their way through (the bubbles are the sort of size that you would see rising from the bottom of a glass of beer.. really tiny, and only 1 of them after about 5-10 squeezes of the lever)
I bled the system whilst the caliper was supported in an upright position on the rotor in front of the fork, putting nearly a litre of fluid through to ensure there were no rogue bubbles.
I’m still able to push the bike forwards with the lever fully applied, with the tyre clearly rotating about an inch each time I rock the bike forwards.
I’m also wondering if the lever is right for the bike.
The previous owner has ‘modified’
the levers so that the bobble on the end is removed and when I first took the lever off, two thin washers, the size of the face of the MC piston fell out so I’m assuming these were used to give more leverage (I’ve checked it against images of the stock ones and it appears that the pivot end is the same!!)
