I believe NGK resistor plugs are 5k ohms built in. If your caps are 5k ohms you should be alright. If they measure much more than that you may start having issues particularly if you have stock coils.
I was having a slightly not perfect idle running NGK iridium resistor plugs with non solid core wire and Dyna 3 ohm coils. Measured resistance of wires and worst was 9300 ohms, that plus 5k in the plug is a lot. Replaced wires with copper core and it idles better. Also cleaned plugs while I was in there, though they weren't particularly bad, but that may have contributed to the improvement too.
