Author Topic: Can we not display images using the [img] tag?  (Read 1465 times)
Offline juntjoo
« on: November 14, 2017, 04:18:19 PM »
There is even a button in the tools to add this functionality but actually not only in these forums I'm finding these days you can't display images remotely like that anymore. I see people are adding images via on site storage but that is limited hence my interest in displaying remotely. Am I out of luck now? If so, how much space do we have to store images and what happens when you inevitably run out? Thanks
-Ben
82 Nighthawk 650..
1982 Honda Nighthawk...
I HAVE A 1982 HONDA NIGHTHAWK FFS! j/k. It's my only bike, my first and last.
Offline Ridem32
Re: Can we not display images using the [img] tag?
« Reply #1 on: November 14, 2017, 04:38:28 PM »
Use the app Tapatalk for forums. Post pics right from your phone
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: November 15, 2017, 01:29:02 PM »
Remote hosting images still works fine here.  I use Imgur now, but most any image hosting site should work.  Just put the direct link between the "[img]" tags, and your pictures should show up.
Offline juntjoo
« Reply #3 on: November 15, 2017, 03:10:35 PM »
That's what I've been doing and I can only get a link not a direct display
-Ben
82 Nighthawk 650..
Offline Gordon
  • 750K1, 550K2
« Reply #4 on: November 15, 2017, 04:05:17 PM »
Let me try again, just to make sure.
Still working on my end, and I don't have any special permissions for image linking that I know of.
This is exactly what I put:  (img]https://i.imgur.com/aeoLcTQ.jpg[/img)  Just replace the outer parenthesis with brackets.
Offline juntjoo
« Reply #5 on: November 15, 2017, 04:11:38 PM »
Here I'll use the button in the tool bar above here...
Now I'll manually type it:
Let's see...
Edit: didn't work. Not anywhere else either. I'll paste what I put: ""
« Last Edit: November 15, 2017, 04:13:53 PM by juntjoo »
-Ben
82 Nighthawk 650..
Offline juntjoo
« Reply #6 on: November 15, 2017, 04:15:41 PM »
Above between the quotes I swear is the url, or at least I pasted it in there so I think it's reading it but not displaying anything. Maybe it does work but there's a delay?
-Ben
82 Nighthawk 650..
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: November 15, 2017, 05:43:18 PM »
Copy and paste this:
(img]https://i.imgur.com/pbLjNgd.jpg[/img)
but change the outer parentheses to brackets.  Let's see what happens.
« Reply #8 on: November 15, 2017, 06:20:19 PM »
Looks fine to me.  ;D ;D ;D ;D ;D ;D
Offline Gordon
  • 750K1, 550K2
« Reply #9 on: November 15, 2017, 08:27:35 PM »
That's working great for me, too, Bobby! ;D
Offline FuZZie
« Reply #10 on: November 15, 2017, 10:42:31 PM »
Put what your trying to use in the code tags below, this allows the software to display with out running it.
Code: [Select]
[code]put your link here[/code]
So Gordon's link would look like this:
Code: [Select]
[img]https://i.imgur.com/pbLjNgd.jpg[/img]
Next see: "Code: [Select]"  Clicking [Select] will highlight everything in the code box for exact copying. ;)
Offline FuZZie
« Reply #11 on: November 15, 2017, 10:47:21 PM »
Side note Gordon, you see the BBcode error: the ending /code < should have been displayed in the box. Most likely a small syntax error when adding the BBcode.
Edit
Error 2: [Select] seems to fail also... :(
« Last Edit: November 15, 2017, 10:53:55 PM by FuZZie »
Offline Old Moe Toe
« Reply #12 on: November 15, 2017, 11:00:12 PM »
How do you get a picture that size on there Bobby?
Offline juntjoo
« Reply #13 on: November 15, 2017, 11:30:39 PM »
Code: [Select]
I'll have to try from my pc as soon as I boot it up. I usually use my phone but I don't see what the problem could be on a phone. Thanks for input
Well look what happened but check out what happened to the code:
Code: [Select]
[img width=600 height=450]https://i.imgur.com/pbLjNgd.jpg[/img]
« Last Edit: November 15, 2017, 11:37:09 PM by juntjoo »
-Ben
82 Nighthawk 650..
Offline juntjoo
« Reply #14 on: November 15, 2017, 11:38:49 PM »
What is that, a chunk of brie cheese?
-Ben
82 Nighthawk 650..
« Reply #15 on: November 16, 2017, 10:57:06 AM »
10 years of running the Babe Thread Moe LOL.  Seriously it is a link and that governs the size.
« Reply #16 on: November 16, 2017, 02:25:37 PM »
FYI - when using Flickr, you can choose the size of the pic...
Offline Gordon
  • 750K1, 550K2
« Reply #17 on: November 16, 2017, 09:03:18 PM »
That's a washed-rind (funky), soft-ripened cheese from Vermont, a beer from Austin and a banana from Costa Rica.
Offline juntjoo
« Reply #18 on: November 16, 2017, 09:17:39 PM »
What worldly taste!
-Ben
82 Nighthawk 650..
Offline Old Moe Toe
« Reply #19 on: November 16, 2017, 11:59:22 PM »
Well thanks for the tip Steve-O. Best I go and find out about flickr then. Pics always look better when you can see em better.
Whereabouts in central Texas are you?. Was over there a few months ago and we had a ball.
« Reply #20 on: November 17, 2017, 06:44:13 AM »
I'm just outside of Austin by Lake Travis.
Wish I had known, would like to have tossed back a few with ya Mate!
