Author Topic: 750 valve clearance while degree-ing  (Read 778 times)
Offline my name is nobody
  • I like Pontiacs and Hondas
« on: November 16, 2017, 07:22:19 PM »
Should the valves be set at cold spec or 0 when degree-ing a stock factory Honda camshaft?
thx.
Re: 750 valve clearance while degree-ing
« Reply #1 on: November 16, 2017, 09:40:13 PM »
Zero lash when degreeing.
Offline DaveBarbier
« Reply #2 on: November 17, 2017, 01:44:00 PM »
MRieck recommends running lash. That's what I did. Manufacturer recommends zero lash as it should say on your card. If you do running lash, be sure to subtract the running lash from the valve lift measurement. Like if the card says check the wheel at .040" and your running lash is .005". Your new lift measurement is .035"
« Reply #3 on: November 17, 2017, 05:27:36 PM »
thanks guys 8)
« Reply #4 on: November 17, 2017, 11:17:32 PM »
Do both, 0 lash to measure the cam and compare with cam data. Running lash to adjust the reality.
