Author Topic: CB550 frame plate  (Read 2724 times)
Offline Anthub
CB550 frame plate
« on: November 17, 2017, 10:21:41 AM »
Can anyone tell me what this is....Looks like some kind of build plate held on with tiny rivets... Can it be removed?
Offline Ridem32
Re: CB550 frame plate
« Reply #1 on: November 17, 2017, 10:33:52 AM »
Looks like it’s been pained over. I really cannot see it in you pic.
Offline Anthub
« Reply #2 on: November 17, 2017, 10:35:32 AM »
Yeah.. it’s painted over ... I just wondered if it was something all 550s had
Offline Anthub
« Reply #3 on: November 17, 2017, 10:37:57 AM »
It’s on the tube that leads from the top of the shock down towards the swingarm on the right side of the bike
Offline Scott S
« Reply #4 on: November 17, 2017, 10:39:29 AM »
 Not stock. Looks like someone removed the side cover tabs and got a little giddy with the grinder and made a plate to cover it up.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Anthub
« Reply #5 on: November 17, 2017, 10:40:19 AM »
Ahhh... that would make sense
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=qcfupcmjaucg3hhhqrfs46ou46&/topic,60973.0.html
« Reply #6 on: November 18, 2017, 09:06:40 AM »
can it be the type plate.(in a vrong place).vith max load..and total vaight frame number and so on..on 400 four it are on the front tube..often korodet heavy..as it are a aluminium plate..
i hate all this v-w.... vords
Offline jlh3rd
« Reply #7 on: November 19, 2017, 03:14:00 PM »
No.
Offline Gene
  • Chat enuf you too can be a
« Reply #8 on: November 19, 2017, 04:08:37 PM »
Be careful removing - it could be the only thing holding that part of the frame together. 1/2 kidding :)
*1973 CB750K3 (Bow)
Offline strynboen
« Reply #9 on: November 20, 2017, 01:59:45 AM »
its the type plate..have just thekked my euro spec k3 1978..is the us modells different?..or is all 550 made this vay
must say your builder vas a fzuk..as he not drilled the small rivets..and painted..and then re"riveted it on after..be care to thek all stuff..on the bike..this is not a good seighn..
« Last Edit: November 20, 2017, 02:04:43 AM by strynboen »
Offline Anthub
« Reply #10 on: November 20, 2017, 02:01:45 AM »
That’s it.... thanks for that (again) ... you are a mine of information
Offline Anthub
« Reply #11 on: November 20, 2017, 02:04:27 AM »
I’ll take it off when it comes to powder coating the frame
Offline Scott S
« Reply #12 on: November 20, 2017, 03:23:00 AM »
 That's not on the US models.
'71 CB500 K0
'81 Yamaha XS650
Offline flatlander
« Reply #13 on: November 20, 2017, 05:35:31 AM »
yes that's the spot where the vin plate is mounted on the euro models.
don't know what the law is in your neck of the woods but you probably should have this on the bike in legible shape. i agree with stryn, whoever did this was a bit of a knucklehead.
Offline Anthub
« Reply #14 on: November 20, 2017, 05:47:22 AM »
Yeah... I’m discovering quite a few knucklehead modifications since I bought it... I’m learning new stuff fixing them though, so it’s not all bad
Offline Anthub
« Reply #15 on: November 20, 2017, 05:48:34 AM »
It’s got a frame number and an engine number which is enough to comply with the law in the U.K.
Offline strynboen
« Reply #16 on: November 20, 2017, 08:12:20 AM »
you still have all the stamps at the stering head..so it are just a ekstra éasy info plate...think you can pass a test even vitaut it..if you have the info on paper..to dukenment the data..on 400 four it  lov at the front tube..and often korodet to hell..have mine strapped in the Tool box..after it vas so Loose i vas afraid to Loose it..
Offline Anthub
« Reply #17 on: November 20, 2017, 09:23:18 AM »
To be fair, when I get the frame powder coated, it won’t be going back on
Offline strynboen
« Reply #18 on: November 20, 2017, 09:33:05 AM »
you can epoxy it on the tube under the seat..or just forget it..
Offline Anthub
« Reply #19 on: November 20, 2017, 09:34:04 AM »
Offline Anthub
« Reply #20 on: February 18, 2018, 03:33:57 AM »
Just a bit of an update chaps... Took it off this morning..confirming it is a build plate.. cheers
