Author Topic: RC angle drive gears  (Read 9574 times)
Offline mrboost
Re: RC angle drive gears
« Reply #25 on: February 07, 2018, 10:12:00 AM »
I also have a finned Hunt.  Nothing to complicated inside, very unique cut gear I guess you would call it. About 10 years ago I called Hunt and told them what I had, he said he thought he had some of the gears collecting dust on the shelf so I bought them all!
« Reply #26 on: February 07, 2018, 09:51:59 PM »
Singles or pairs..   that is very interesting. Keep me in mind,   I better check mine.. have you run yours much?
 Bet they don't fit the RC type
« Last Edit: February 07, 2018, 09:53:33 PM by 754 »
« Reply #27 on: February 11, 2018, 01:44:57 PM »
So I found a pic of a spare Hunt mag I have in storage and I can see the points.
So question, does the cam pass under the points, then reach the rubbing block . Or hit the block first?
Trying to determine  rotation to see if it fits my new angle drive.
« Last Edit: March 02, 2018, 05:28:00 PM by 754 »
Offline mrboost
« Reply #28 on: February 13, 2018, 09:19:20 AM »
Some pics
« Reply #29 on: February 13, 2018, 09:21:32 PM »
The shaft with the small gear looks like a VW intermediate distributor shaft. The tangs on the bottom of the distributor engaged the slot in the top of the shaft. The cone shaped part is the cam that operates the mechanical fuel pump. The bronze gear would have been mounted on the VW crankshaft.
« Reply #30 on: February 13, 2018, 09:49:47 PM »
Mrboost did your bolts snap off? Mine is weeping out of the coverplate, I should open it up, check everything and reseal it.
Offline sohc boy
« Reply #31 on: February 14, 2018, 09:01:19 PM »
    yep, thats exactly what they are Scottly, 12>1600 air cooled vw drive gears,i spent way too many yr's working on air cooled vw's
i live by the voice inside my head
Offline mrboost
« Reply #32 on: February 16, 2018, 05:51:16 PM »
bolts all good
Offline mrboost
« Reply #33 on: February 16, 2018, 05:54:17 PM »
I haven't run it, just collect stuff for it.  lol  Spins nice and smooth though.
Offline Buelligan
« Reply #34 on: January 30, 2023, 10:06:19 PM »
Hi there
I realise that this is an old topic and that I am new to the forum but wanted to let members know that if they are still looking for the RC bevel drive gear I have crank gears, carriers and timing plates for the RC angle drives.
I’m sure some members will be upset at an early post from a new member “ peddling wares”
No intention of upsetting anyone but trying to help out.
« Reply #35 on: January 30, 2023, 10:20:23 PM »
 I don't know about upset but maybe wary. It appears you have the goods in hand, let's keep this a secret until I find a cheap RC angle mag missing its gear. Of course, I'm kidding.
Offline Buelligan
« Reply #36 on: January 31, 2023, 03:54:30 AM »
Hi
lol Just between us then!!
fully Understand if anyone is wary
I had the gears made as I needed one and as there was little difference in cost between a one off and 10 off had a batch made.
Im sure Larry Romig is a forum member He had a gear and carrier from me and was happy
Just sent a gear and carrier to Russ Collins Jr!! which I consider an honor!!
Ian
Offline kmb69
« Reply #37 on: January 31, 2023, 06:41:32 AM »
How much and how to order a set?
Keith
Offline Buelligan
« Reply #38 on: January 31, 2023, 02:17:44 PM »
Selling at cost plus postage Keith
Full drive - gear carrier and timing plate $310 plus shipping
Gear $165
Carrier $95
Timing plate $50
Pm for payment details and shipping cost
Ian
Offline kmb69
« Reply #39 on: February 01, 2023, 07:28:57 AM »
I will buy the Full Drive Kit.
Sending PM.
Offline jonnycakes
« Reply #40 on: February 03, 2023, 08:54:51 AM »
Are these bronze?
'Matic-Fanatic
Offline Buelligan
« Reply #41 on: February 03, 2023, 09:01:53 AM »
Yes they are
Offline gschuld
« Reply #42 on: February 03, 2023, 04:16:57 PM »
Thanks for making these.
(FWIW, I bought a set)
George
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #43 on: February 04, 2023, 08:59:41 AM »
Very cool, thanks for letting us know about these. Glad the Sorcerer got a spare.
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
Offline Buelligan
« Reply #44 on: February 04, 2023, 01:09:46 PM »
For those looking for the larger internal gear there are two types: a one piece gear with machined VW dog drive machined and a 2 piece where the dog drive is a separate piece that’s then welded to the gear.
Same bearings and locating shaft/pin
Thinking of getting these made up as well if anyone is interested
« Last Edit: February 04, 2023, 01:14:04 PM by Buelligan »
Offline NitroHunter
« Reply #45 on: February 05, 2023, 06:56:36 AM »
Did the larger gears fit any of the RC angle drives?
Offline Buelligan
« Reply #46 on: February 05, 2023, 08:01:24 AM »
Yes I believe so
Offline jonnycakes
« Reply #47 on: February 07, 2023, 06:02:16 PM »
I had a welded one that got ruined, ground off he welds and replaced it.  The replacement did not have welds, but was still a two piece. Used green locktite to secure it.
'Matic-Fanatic
« Reply #48 on: February 07, 2023, 06:32:40 PM »
 And they said it couldn't be done....
« Reply #49 on: February 07, 2023, 06:46:47 PM »
Remember guys, these drives are not suitable for use with high power magnetos. ;)
