Support the site. Your contributions keep this site running.
the 77 has a longer countershaft,so with the 72 bottom end you will have drive chain issues,you could put the crank out of the 72 in the 78,but would likely have to put new main bearings in unless you get real lucky
77,and 78 are the same,yes the crank will save your build,if the rod bearings in the 72 are good you can swap rods and all,but check them when you have it apart
You could just put the '77 top end onto the '72 bottom end, then find a 630 sprocket for the CB750F2 bikes, and drill some 6mm holes into the sprocket to mount it with the little floating plate. Or, maybe check with CycleX (or sometimes at Joker) to find their "630 sprocket for early CB750 engines", which they offer from time to time. These cost about $35, but solve the problem very neatly.
