When I was doing mine, about 4 years and 15,000 Kays ago I bought the ape studs and had to buy nuts separately thinking I would need hd nuts, jeez you'd think the studs would come with nuts? Anyway I bought HD nuts from I have no idea where but I thought they were a tad loose on the stud threads so I just left the stockers in there. The ape studs are still here somewhere.
While more torque on the head gasket would be a good thing I don't know of anyone back in the 70s ( when we were all doing yoshi 812 kits with a domed piston for more compression) who put HD studs in, I never even heard of them and I was a mech in a Honda shop, brfff, loosly speaking
Of course, back then we didn't even put sealer on the pucks, I dunno how different the pucks are today and as Mark has said, gaskets today are taller. 40 years on and there is so much more to know about these beauties.
I wonder how many blokes have used the Crusinimage gasket and just not bothered retorquing. I have 3 of them here but won't ever use em, I will buy the Yamiya gasket in future as I KNOW it is a good gasket. I must admit, I didn't measure the thickness though.
I have a Z900 as well and it has the Crusinimage 69mm pistons and the gasket needed retorque as well. I now use the Vesrah gasket on it simply because I bought one and used it and it did NOT require a retorque,
I have not idea if the Vesrah for the Honda is the same.
I have also read that on the later engines with the 8 rubber seals and pins that you don't need to put them in, I left them out and had leaky gasket, I put them back in and have not had leaky gasket but have had leaky pucks but I'm hoping now that all my threads are good in there I have fixed it for good this time but I won't be surprised if I get leaky pucks in the future, with the frame kit it's a mornings work.
I have 11x2.5 Orings between barrels and cases, no leaks, I do have the 10.77x2.61 Orings in stock but I just have no idea if they are in there between head and barrels, no leaks there either.
So to HD stud or not? I don't think it's a necessity? It hasn't been a problem for me after 15,000 Kays, I don't flog the engine though.
