Author Topic: Cant remove kick start pin  (Read 1032 times)
Offline 1976ssport
« on: November 26, 2017, 10:09:36 AM »
Hi All,
Just building my first 76 SS motor.  Have the whole thing torn down except the kick start assembly.  I tried removing the pin that holds it in but cant seem to get it.  I grabbed the end with a vice grips and heated the block with MAP gas.  Cooled and repeated 3 times with PB blaster.
Any tricks of the trade to share?
Thanks in advance.
Rick
Re: Cant remove kick start pin
« Reply #1 on: November 26, 2017, 10:36:54 AM »
 Did you grab the pin in a position where the slit was orientated correctly so it would contract somewhat. I have squeezed the pin with a pair of old dull wire cutters before down low close to the case metal and tapped the cutters with a small hammer on engine cases I was just parting out.
« Last Edit: November 26, 2017, 10:42:34 AM by ekpent »
Offline 1976ssport
« Reply #2 on: November 26, 2017, 02:43:52 PM »
I haven't tried that yet.  Will give it a go.
Offline Kevin D
  • SE Michigan
« Reply #3 on: November 26, 2017, 06:56:07 PM »
Ekpent is on to it.
It's nice the search is working, I found this pic and reply from 2008:
I used the diagonal pliers and popped the pin right out. Grab the pin as close to the case as possible. Just squeeze hard enough to get a bite, then push down, using the handles as a lever.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline magnum56
« Reply #4 on: November 27, 2017, 06:32:30 AM »
Ekpent is on to it.
+1
Side cutters worked very well for me as well.  And don't worry too much about scaring the split pin some, it will just improve the grip when driven back into place on reassembly.
'74 CB750K
Offline 1976ssport
Re: Cant remove kick start pin "solved"
« Reply #5 on: November 28, 2017, 06:42:46 PM »
The side cutters worked great.  Thanks so much for the advice.
Rick
