Author Topic: Electrical enginers,please chime in,Led,s h4 bulb to reduce current draw?  (Read 7203 times)
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
I'm looking at these 2 h4 bulbs for my bike?
It doesn't charge enough to start when I'm doing lots of test runs to determine carb settings, have to charge battery monthly to keep it starting?
But during summer when riding on longer than 5 mile test run s, I never have to charge?
I'm thinking bout a led h4 bulb to reduce current draw?
Will either of these perform as well as a stock Hal h4?
://www.ebay.com/itm/332336399767
://www.ebay.com/itm/122801160414
Thanks!
I don't understand a all the SPECS?
Recomandation?
Re: Electrical enginers,please chime in,Led,s h4 bulb to reduce current draw?
« Reply #1 on: November 29, 2017, 01:19:52 PM »
My recomandation: ride a bicycle and only bring your motorcycle out for rides the motorcycle was ment for. Problem solved. Guaranteed.
Offline FuZZie
« Reply #2 on: November 29, 2017, 01:45:26 PM »
Thanks!
Recomandation?
All these old bikes don't charge at idle, they need to run just that simple.
If your not riding enough or doing a lot of traffic, you may be better off with a battery maintainer.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
« Reply #3 on: November 29, 2017, 05:56:25 PM »
Thanks!
Recomandation?
until i stopped shifting before 4000 rpm and riding longer than 20 minutes i had the same issue.  battery maintainer if you're not doing this.
cb750 k6 - ugly
Offline Garage_guy_chris
« Reply #4 on: November 29, 2017, 06:31:25 PM »
Another solution is to upgrade the regulator and rectifier to a modern combined unit. they are more efficient and make less heat and waste less juice in the production of heat. Both my vintage bikes have upgraded R/R.
74 CB750: yamiya unit, charges at about 13.4-13.6V at idle soon as your above 2000 it jumps to 14.2V the bike has LED lighting and a regular H4 headlight(recently upgraded to a H4 LED bulb) and i have basically never had a charging problem..
71 CB450: Known to be crappy charging system; Podtronics Single Phase R/R, Smaller Battery, all LED except H4 headlight bulb: this one breaks even at idle 12.7v, above 2000 it jumps to 13.4+, have never had issues with this one either.
Offline spotty
« Reply #5 on: November 29, 2017, 08:37:51 PM »
they won't reduce current draw, they're 72W, your average H4 halogen is 35/55W, as was the original sealed beam POS.
as for will they work better ? you won't know unless you try them or get a report from an actual user. I've tried several different LED H4 replacements and they've all been cr@p, these ones look a lot better than the earlier ones I was using which had no appreciable thrown beam, you could see the headlight from the moon but I couldn't see anything on the road. all to do with the diffused light from the LED's and the reflector on the bike. these look like they have a more focused light sending area (if that makes sense)
i'm using a 90/110W H4 halogen (permanently on and permanently on high beam ) now and it works a treat and doesn't suck the battery dry but I don't get the bike out for anything less than a 20 mile ride and I have a gel battery which makes a huge difference to charge life
i blame Terry
« Reply #6 on: November 29, 2017, 09:56:24 PM »
My CB750 K6 had H4 from the very beginning, bulbs specified 60/55W.
I have tried LED bulb in rear lamp, CRAP! The 21/5W bulb is much better and will lit better when braking wich is very important to show the traffic behind.
LED H4 for headlight however, is working really fine with a very bright light and a little bit less wattage, 30W according to its specification.
CB750 std charging system work fine. I charge the battery for a few days every month or 2 when not used to keep the battery in good shape. Cheap GEL battery.
« Reply #7 on: November 30, 2017, 04:54:02 AM »
So watts is the speck I should look at, 35 watt or Less?
I thought the watt spec for a led bulb was an equalivant to compare to a regular bulb,
And they drew less than That?
I'm not familiar with electrical terms?
And if I want to upgrade my system, I can just change my regulator,Rectifier?
No stator change?
How about the lumin  spec, what's comparable to a stock 55w h4?
Thanks all.
I really like the regulator upgrade idea, what do I search for on ebay?
Offline KeithB
« Reply #8 on: November 30, 2017, 05:14:24 AM »
Yes, watts is what you look at when calculating the load on the charging system.
As for lumen specs, most LED H4s will be brighter but, in most cases, the pattern control is terrible.
You can change to a modern rectifier/regulator quite easily. Look on Vintagecb750.com
That said, just get a battery tender/charge. You should have one as part of your tool kit anyway .
Nanahan Man
Offline calj737
  • I refuse...
« Reply #9 on: November 30, 2017, 05:53:43 AM »
This is simply not accurate. Solid State Reg/Rec units don't produce more amperage than the stock units, they just produce and manage what is available a bit more efficiently. That doesn't equate to more available amps though.
As was stated, you need to concern yourself with wattage rating for all headlight bulbs. That is the "draw" on the electrical system. A thorough maintenance of your charging system and all electrical connectors is also a very good exercise to maximize available amps (or minimize resistance and charge reducing issues).
« Reply #10 on: November 30, 2017, 11:06:45 AM »
So what do the modern bikes have in them? They are quiet a bit brighter and larger beam pattern,than our old stuff?
Even the h4 standard that I upgraded to from a sealed beam [lots better] isn't on par with my
10 year old cars?
Getting older, sight worsening ,after driving a 2005 camry,or my 03 Chevy cargo van,the h4 on my bike seems so Weak?
What's the most budget friendly upgrade for my h4 housing?
I'm going to measure my bucket, and if theirs room I'm going to be the genie pig, and try one of those ebay China h4 led fan cooled bulbs?
Thanks
« Reply #11 on: November 30, 2017, 11:27:19 AM »
Yes, I agree.  However, the Regulator and rectifier don't produce anything.  The rectifier converts AC to DC current.  If your existing rectifier is silicon based, a "modern" one won't be any more "efficient", particularly if the same diodes are "blown" in each example.
The regulator only controls what the Alternator creates.  The stock mechanical one is actually more efficient when properly tuned, as a mechanical metal to metal contact transfers all voltage and current.  Electronic devices consume a bit of power for the same transfer path.  So, peak output is somewhat diminished by simply going to an electronic alternative.  It's not all that much, though.  But, if one is going to tout "efficiency",  facts are facts.
I speculate that when the uninformed try to willy nilly "adjust" a working stock regulator for an expected and unreasonable outcome and are disappointed, they toss it in favor of "modern", without ever checking the rest of the circuit for flaws.  And thereafter the goal is to justify an otherwise unnecessary expenditure as a self gratification exercise.
In short, an electronic regulator can't make the existing alternator produce more power.  And, if it is a "forcing" regulator, it can overheat the alternator's windings, requiring alternator replacement.  It depends on your particular alternator's individual build robustness.
« Reply #12 on: November 30, 2017, 11:34:56 AM »
H4 light pattern is better than the LED H4 I have. But LED H4 give me respect by the other cars, I'm visible! I have not tested long range riding on dark roads with LED H4 yet, the light make the road and surrounding forest visible as I have seen so far
Worse light pattern will only be a problem at the annual vehicle inspection when I change bulb just for sure. I have only one inspection left on my K6. No protesting meeting cars on dark roads.
New law on old bikes (like 35 years old) 2018, no annual check anymore.
Try one!
I have this in my bike ( Have newer and stronger on the shelf (40W).  Cree Led Parking light lit together with HI adding some.
http://www.ebay.co.uk/itm/Super-Bright-Car-Truck-CREE-H4-LED-30W-D-6500K-3000-Lumen-Head-Light-Lamp-White-/271882198751?_trksid=p2047675.l2557&ssPageName=STRK%3AMEBIDX%3AIT&nma=true&si=sSS9zkDr7Er8uH6Ovbt1fMXqVPQ%253D&orig_cvip=true&rt=nc
I have also an electronic regulator that replace Hondas electro-mechanical  regulator and rectifier. NOT for more power, hopefully more accurate voltage output without overcharging.
I can't install it before the stock stuff is proven to work on my ongoing CB750 K2.
Risk to burn the alternator since the overvoltage is not burned away make me to hesitate if its good. I found it on Aliexpresss for half price than found on eBay.
« Last Edit: November 30, 2017, 11:43:13 AM by PeWe »
Offline prosolar
  • I've seen things that would make you shit out a book about puking
« Reply #13 on: December 02, 2017, 03:05:19 PM »
I think the hot ticket is having a good quality headlight housing that has the blocker. The H4 halogen bulbs have one built in so a lot of cheap housings don't have a blocker or need it until you put in a LED or HID. With the blocker you get way more focused light and less glare to oncoming traffic. Hella and Bosch 7" round have the blockers.
https://www.amazon.com/HELLA-002395801-Halogen-Conversion-Headlamp/dp/B0002M9QK6/ref=pd_lpo_vtph_263_bs_t_1?_encoding=UTF8&refRID=13926XWTETY1XSWXGC29&th=1
69' CB750
75' CB550K
78' CB550K
79' KZ650
82' GS1100G
04' Bandit 1200S
Many others
Offline FuZZie
« Reply #14 on: December 02, 2017, 05:18:17 PM »
Another bit of info is that reflector should be designed for a bike and not a car, they are not equals!
« Reply #15 on: December 04, 2017, 05:19:35 AM »
Bike off, bat voltage 12.8 V
Switch on not running,headlight on  12.1 V
Start bike idleing. 11.8 V
At 3k  12.2V
At 5k 12.9V
The light does brighten when reving the engine.
These numbers seem low?
Do I maby need a reg-Rectifier?
Thanks
Offline John Eberly
« Reply #16 on: December 04, 2017, 08:43:40 AM »
The two parts of your equation -
Power into your battery is determined by the alternator output. If the coils are weak or shorted you will have low voltage and the regulator can't fix this.
Power out to your bike is determined by the load you are supplying. "High performance" (low resistance) coils and high output headlights draw extra current and tend to lower battery voltage.
It seems like the LED headlights are designed for extra output and not for energy savings - they draw the same amps as the stock lights but are brighter. So changing to these does not reduce load and does not seem to improve battery voltage. If you can find an LED lamp with equal lumens to the stocker at a lower wattage you can cut the load and help your battery out. I have not seen one yet, but I'm not looking either.
« Reply #17 on: December 04, 2017, 09:40:14 AM »
This is a good sign
Still OK  Battery clearly loaded down.  The loss can be from either loading or weak capacity of battery.
Start bike idling. 11.8 V
Again battery drained from electric starting.  Wouldn't it be nice to know if you bike was a power hog or your battery is weak?
At 3k  12.2V
Well it IS charging.
At 5k 12.9V
Not charging very fast, is it.   That's kinda of a good thing.  You don't want the battery to deplete quickly.  But. the charging system isn't going to charge it up fast either.
At 5K RPM, it is nice to know trend voltage as well as instantaneous voltage.  Clearly the voltage is rising. Would it eventually get to 14.5V?  The 750 can put out about 14-16amps/ @~13.5V  or 210 Watts of power when revved up.  Only about 1/3 of that power is available at idle RPM, due to reduced rotational speed.  But, unless the bike consumes less than what the alternator creates, the battery charges at a rate commensurate with the "leftovers".
Example:  Stock bike uses about 10 amps with lighting on.  At idle the alternator makes ~5-6 amps.  Battery drains to make up the deficit.
That's jumping to an unsupported conclusion.
Parts substitution can effect a repair. Throwing money at the problem can work.   But, how will you know if something other than the R/R is causing the fault?  What if one of the three alternator windings has an open connection?  That would reduce alternator output capacity by at least a third.
What if the alternator field coil isn't getting full battery voltage.  That will also reduce the alternator output capability.
There are other items besides the R/R that can cause weak alternator output.  And, of course a weak or worn battery can exacerbate performance, too.
Have you tried disconnecting the white wire from the Vreg and jumpering it directly to the BAT POS terminal and repeating the RPM test?  Look for voltage trends.
Were it me, I'd do more testing before replacing untested components.
Charging system methodical verification checks, CB750, CB550, CB500, CB400, and CB350.
Begin with problem verification and characterization with recorded data.
A -- Fully charge a known good battery.  Let it rest for 2 hours, off the charger, and measure the battery voltage.  (Target is 12.6-12.8V.)
B -- Start the bike and measure the battery voltage at idle, 2000, 3000, 4000, and 5000 rpm.
C -- Repeat the measurements of B with lighting off.
The above tests identify charging system success, failure, or degree of "faulty".  The success voltages are listed in the Shop manual.
D -- Assuming the above indicates faulty, do check the RECTIFIER diodes with a diode tester or ohmmeter capable of testing diodes and uses more than .7 volts to make the test(s).
Of the twelve test made in D, six must read low ohms and six must read very high ohms.
E- assuming no faults were found in D,  Measure the white and green wires disconnected from the REGULATOR.  CB750s should 6.8 ohms - ish,  CB550s/350s/ and 400s should read 4.9 ohms- ish.
F- If there are no bullet holes or road rash/divots on the alternator case, the stator is probably good.  But, you can check for yellow to yellow continuity (.35 ohms) among all the wires, and that no yellow wire has continuity to the engine case.
G- Assuming no faults found in D, E, and F, measure the disconnected terminals of the REGULATOR.  The black and white terminals should measure zero ohms (subtract meter error if there is any).  Higher than Zero ohms, indicates internal contact contamination needing cleaning and attention per shop manual.
H - Assuming D, E, F, and G have not found faults. We can verify all the of the charging system minus the regulator is functioning correctly, by using a temporary jumper to connect the disconnected white wire (normally attached to the REGULATOR) and connecting the White directly to the the battery POS terminal.  Repeat the B and C tests.  However, if at any time the battery voltage rises above 15V, stop the test.  Such an indication would prove the charging system capable of maintaining a known good battery.  If this test never achieves 15V, then there is a wire/connector issue in either the ground path leading back to the battery NEG terminal, a wiring/ connector issue withe the rectifier RED path to the battery POS terminal, or you made a mistake in D through G.
I - (not used, can be confused with L)
J -  The only parts that remain to prove or expose are the REGULATOR (in active mode) and the electrical path between the battery POS terminal and the black wire that connects to the REGULATOR.
K - Lying to and starving the regulator
The regulator can only do its job correctly if it gets a proper voltage report of true battery voltage status.  The Vreg monitors the Black wire for this status.  Measuring the voltage lost between the Battery terminals and the Vreg connections identifies problems that are not really the charging system's fault.
Two connection paths must be checked, the Battery POS terminal to the Black wire connection at the VReg, and the Battery NEG terminal to the Green wire connection to the Vreg.  A volt meter can measure these losses directly by placing a probe between the two identified points, Black path and then the green path.  The numbers are summed and the error seen by the Vreg quantified.  Anything over .5V loss is cause for concern and anything over 1V is a certain issue to be corrected.  Each connector, terminal, fuse clip, or switch in the pathway can cause voltage reporting loss.
The regulator also passes the received voltage on to to the Alternator field coil to create a magnetic field within the alternator,  The voltage level determines the strength of the magnetic field and the maximum output capability of the alternator.  Therefore, starving  the Vreg of true battery voltage leads to reduced max output capability of the alternator.
L - regulator operation/verification.
  The Vreg sends voltage to the alternator field in response to measured voltage which is battery state of charge.  Any voltage at the battery of less than 13.5V sends full black wire voltage to the alternator's white wire.  The alternator output will vary with RPM, even if "told" to produce max power by the Vreg.  If the alternator has enough RPM to overcome system load, any excess power is routed to the battery which will raise the battery voltage (slowly if depleted and rapidly if nearly full).   When the battery reaches 14.5V, the regulator reduces the voltage to the alternator, reducing output strength and preventing battery overcharge.  If the battery exceeds 14.7V, the regulator clamps the alternator field coil power to zero (0V), effective shutting off the alternator.
Because, there is electrical load from the system, an alternator that is not producing power allows the battery to deplete and the voltage falls.  The Vreg responds by turning the alternator back on in accordance with battery state/ charge level.
The Vreg state changes can be monitored/verified by observing the battery voltage state, and the White wire to the alternator field.  (Two meters are handy for this.)  The "trip" voltages can be adjusted with the adjust screw, while changing engine RPM and electrical load that the bike presents to the battery/charging system to "make" the battery reach the voltage levels need for the set trip points.  IE. with load reduced (lighting off) and the engine above 2500 RPM, a charged battery will attain 14.5 V.  Anything above that and the adjust screw needs to be backed out to keep the battery safe from harm.
The shop manual outlines bench set up mechanical adjustments that should be performed on unknown or tampered units.  These should be resolved before final trip point adjust tuning.
Note that while the system is working, the Vreg can change states rapidly before your very eyes., changing 5 times or more while you blink.  Therefore, you may have to mentally average values measured on the White wire if your selected meter doesn't do that for you.
« Last Edit: December 04, 2017, 09:42:11 AM by TwoTired »
« Reply #18 on: December 04, 2017, 05:50:10 PM »
Thanks, I'll do some more Testing.
Offline KeithB
« Reply #19 on: December 05, 2017, 04:18:44 AM »
10 year old cars?
Thanks
Good lighting is all about a well designed optical system that works with the light source it is designed for. I suspect more money goes into the design of car headlights than bike lights, at least older ones.
Modern motorcycles do use LEDs but the optics are designed correctly.
Installing an aftermarket H4 will not work the same as the original halogen bulb and usually results in a bright light but with poor pattern control. There is supposed to be a low beam "cut off" so the light doesn't affect on coming drivers. You can see this pretty clearly on most car headlights.
I tried out a set on 2 different bikes and results sucked. Bright ..yes, but crap pattern. Sold them.
Yes, you might get "respect" from other motorists but, in most case, the cut off is poor and there is a lot of glare to oncoming drivers. Just because no one flashes you doesn't mean there isn't glare.
I can tell pretty accurately when someone had installed aftermarket LED or HID as the glare is quite obvious. When the car behind you is lighting up the overpass bridge, on low beam, something ain't right!
The trial and error of H4 retrofit has been covered covered very well on many other bike sites.
see...
http://www.fjrforum.com/forum//index.php/topic/170297-led-headlights/?hl=+led%20+headlight
« Last Edit: December 05, 2017, 04:20:48 AM by KeithB »
Nanahan Man
Offline Dunk
« Reply #20 on: December 06, 2017, 05:58:34 AM »
Both of those bulbs you mentioned are cheap Chineses junk. They will likely produce less useful light than even the factory sealed beam. To improve lighting and potentially reduce draw by the headlight you need to upgrade to a quality H4 reflector. Cibie is generally regarded as the best, I use them in several vehicles and am very pleased. https://www.amazon.com/dp/B008DQV88Q
For a headlight bulb you can use either Philips XtremeVision or Osram nightbreaker if you want maximum light output. For far better than sealed beam but lower current draw look for a lower wattage bulb. Candlepower (and others, not Chenese junk off ebay) sell quality low wattage H4 bulbs. http://store.candlepower.com/mobu.html
It would be prudent to do relays for the headlight regardless, but particularly if you're running a higher than 35 watt bulb.
Aside from that, fix your charging system. Others have covered it, but for me cleaning all connections, replacing the junky ones, and using a solid state regulator from Oregon Motorcycle Parts resulted in my charging system working much better. I'll also note by rectifier was new as well, but the old one was quite melted.
« Reply #21 on: December 08, 2017, 09:39:53 AM »
Cleaned my fuse tabs,and plug in connections.
I'd like to adjust the volt Regulator?
How?
« Reply #22 on: December 08, 2017, 10:07:38 AM »
How?
First question is why?
next is;  Have you looked in the Honda shop manual?
Do not try and use that device (vreg) to compensate for poor wiring connectors or switch contacts.
This will lead to boiling batteries, long term.
The voltage adjustment is actually a limiter only.
Measurement point is at the output of the Vreg, across the the black and green terminals, NOT at the battery.
The set up condition is having a known good fully charged battery installed, and the engine revved so the battery voltage can increase.  As long as the voltage never exceeds 14.5V, that is the adjustment limit point of the stock Vreg.
« Reply #23 on: December 08, 2017, 01:41:29 PM »
But it is normal that the voltage sometimes exceed 14.5V for a few minutes, right?  I have seen that on my CB750, with headlight on, as usual.
Or is it better to adjust the regulator and reduce the voltage? Battery is a cheap GEL battery.
Edit: ch 8 in manual attached, read all first then service the regulator if needed
« Last Edit: December 08, 2017, 01:44:12 PM by PeWe »
« Reply #24 on: December 08, 2017, 02:09:19 PM »
After the cleaning of tabs and plugs and points in reg.
Battery key off before start.   12.8
Key on,light on after 10 seconds. 11.6
At idle.  11.4
2k.   12.2
3k.   12.9
4k.   13.4
5k.   14.
Way better, headlight brighter.
And first tme I went to 5k it went to 14.8 for just a little while then settled back down to 13.8-14v.
The fuse tabs were nasty?
And some greenish stuff at the plug leaving the engine case?
Amazing what a little cleaning will do?
Thanks!
