Author Topic: XL350 Wiring question  (Read 2004 times)
Offline pbr23n
« on: December 03, 2017, 08:16:18 PM »
I'm putting together an XL350 flat tracker but have something wrong with my wiring and keep blowing the fuse... Can someone point out what's wrong?
I have a simple on/off switch, stock charging system and a battery.
Thank you!
Offline CycleRanger
  • No comment about being an
Re: XL350 Wiring question
« Reply #1 on: December 04, 2017, 06:14:50 AM »
Howdy!  :)
Don't know what year your bike is but I'll bet you can find some answers here:
http://forum1.aimoo.com/XLBoard
http://www.oldrice.com/xl_page.htm
« Reply #2 on: December 04, 2017, 10:30:31 AM »
You don't need a battery to Run it..
Offline CycleRanger
« Reply #3 on: December 04, 2017, 10:43:05 AM »
To run the bike true, but if he wants to run any lights at all he'll need a 6V battery of some kind.
Offline pbr23n
« Reply #4 on: December 04, 2017, 10:45:17 AM »
Thank you for the response.
Without lights, would I just connect the points and coil to the main switch power wire and connect the ground wire to the frame?
« Reply #5 on: December 04, 2017, 09:26:50 PM »
The reason the fuse is blowing is you have wired battery negative to one side of the switch, and battery positive to the other side. Turn the switch on, and the fuse goes poof. :o Battery plus from the fuse should go straight to one side of the switch, and the loads should be connected to the other side.
