Author Topic: 69, 69 and another 69 - CB750 projects  (Read 23337 times)
Offline Salman_z8
  • it will all be done one day
    • Fast Track Signs
Re: 69, 69 and a 71 - CB750 projects
« Reply #175 on: March 14, 2023, 10:56:05 AM »
This is how far i am at.
I am very bad with taking photos
69 CB750 - Candy Red - Complete and Running
69 CB750 - Candy Blue Green - future
69 CB750 - Candy Gold - Complete and Running
79 CBX1000 - Candy Glory Red-
80 GS1100E - old friend
And some more … i lost track
« Reply #176 on: March 14, 2023, 03:15:51 PM »
A yellow CBX?
I’ve never seen that.
Offline Salman_z8
    • Fast Track Signs
« Reply #177 on: March 14, 2023, 04:01:01 PM »
A yellow CBX?
PO had painted over the glory red.
It also had a gsxr 1100 headlight fairing, and cheapo turn signals.
I have sourced an original fender. And then bring the tank and cowl back to original colour.
Have a remanufactured headlight shell, turn signals, and fixing the wiring.
« Reply #178 on: March 20, 2023, 11:06:17 AM »
A yellow CBX?
You are a very wise man...
« Reply #179 on: March 20, 2023, 02:50:08 PM »
Good move on the CBX, they are now quite expensive.
Offline Salman_z8
    • Fast Track Signs
« Reply #180 on: March 20, 2023, 04:13:07 PM »
They are for sure.
I have another cbx, but all i had was a frame and engine with a bad top end.
So that is a restomod project
Offline Salman_z8
    • Fast Track Signs
« Reply #181 on: May 26, 2023, 11:00:15 AM »
59 miles on her now
No number pipes, kokusan ignition.
Other than that the bike is original.
Waiting on new brake lines and pads
Offline Salman_z8
    • Fast Track Signs
« Reply #182 on: May 26, 2023, 11:02:26 AM »
Rode this beauty to work.
Also 1969.
It has now 160 miles on it, since full rebuild 4 years ago.
K1 forks and fender and HM300 pipes
Offline Salman_z8
    • Fast Track Signs
« Reply #183 on: May 26, 2023, 11:03:19 AM »
I wana change the thread name, since there is no 71 anymore, and all three are 69’s
Offline Salman_z8
    • Fast Track Signs
« Reply #184 on: May 30, 2023, 02:42:20 PM »
What needles are supposed to be in 1969 diecast 4 cable carbs ?
Marked B750A, i have 27201 .. are these correct ?
I set the floats a long time ago, so cant remember, but should have set 26mm.
40 pilot, 120 main, clip in the middle.
Air screws, 1 turn out.
Carbs are synced, intake manifolds are new.
Compression is 130psi across
Stock air box filer and hm300 pipes
I do get decel pop, intermittently
Plugs are nice and tan, idles good, strong low and midrange.
Will pull red line 1-3, 4th becomes an effort, but will.
5 th tops out at 6k.
Plugs show lean in fifth WOT.
Carbs are as clean as can be. Brass floats.
I did not replace the floats.
Plugs are suspiciously too tan, i havnt had a cb run this clean plugs ever in low mid range.
Possibly float height low ?
Offline Salman_z8
    • Fast Track Signs
« Reply #185 on: May 30, 2023, 02:45:39 PM »
Even a  mm lower/higher, shouldnt affect this much, ?
Timing is perfect.
Will pull in any gear any rpm, no hesitation.
Just comes to a halt in fifth at 6k.
17/45 gearing
Unless i used a k6 cam lol
Offline Salman_z8
    • Fast Track Signs
« Reply #186 on: May 30, 2023, 02:47:07 PM »
And my compression gauge always reads lower.
This is a fresh engine, nice and tight
Offline Salman_z8
    • Fast Track Signs
« Reply #187 on: June 19, 2023, 09:41:14 PM »
Surprising how similar they are  ;D ;D
« Reply #188 on: June 19, 2023, 10:52:36 PM »
I’ve been told the thread owner can edit the first post and change the thread title that way…
Subject line should be editable also…
Offline Salman_z8
    • Fast Track Signs
« Reply #189 on: June 19, 2023, 10:57:29 PM »
Perfect
Re: 69, 69 and another 69 - CB750 projects
« Reply #190 on: June 20, 2023, 05:20:45 AM »
Do you have the rubber gaskets installed, under the carb tops?
Offline Salman_z8
    • Fast Track Signs
« Reply #191 on: June 20, 2023, 10:41:33 AM »
Nope, i never saw any installed in the three sets that i have.
Offline Salman_z8
    • Fast Track Signs
« Reply #192 on: June 20, 2023, 10:43:09 AM »
Funny thing is, identically set carbs, are lean on one bike and rich on the other lol
Both have no gaskets under the top
« Reply #193 on: June 21, 2023, 06:25:29 PM »
Do you have all 4 of the carb's vent hoses routed up and over, behind the airbox? If these are too short or in turbulent air it can affect the torque, especially at high speed, because it reduces the bowl's ability to push fuel up the jets.
Another thing that can cause poor top-end performance (if carb-related) is fuel delivery, either from a [partially or fully] blocked fuel tank vent (in the fuel cap). This slows fuel delivery, especially in fast-moving air around the tank (which is then at lower pressure than still air).
I've also seen the [brass] floats set incorrectly for the K0/1 bikes. They should be staggered 1mm between them, with one float (kickstand side of the bike) at 25mm and the other at 26mm. This was true until the 657b series carbs with the plastic floats came out, around 3/1972.
Offline Salman_z8
    • Fast Track Signs
« Reply #194 on: June 22, 2023, 09:50:21 PM »
Yes, vent hoses are routed behind airbox.
Petcocks is clean, tank is a yamiya replacement.
The only thing that comes to my mind, well two things;
One of my k0’s has its original camshaft, the other one .. cant remember, may be a k4-k6 ..
Secondly, i saw you mention fuel level in the bowl should 3-4mm, below gasket seam, but at 26mm, its more like 10mm. More a pull up, the richer it gets.
Ot may be i should try raising the fuel level to 4mm, go down a notch on the needle, and perhaps go to a 115 main ?
Both bikes have 4 cable carbs, one has early correct cam, and some intake port work, runs a little rich but more power everywhere, compared to the other, but the other does have perfect tan plugs lol well a tad rich lol
Is there an aftermarket cam which is kinda similar to the early cams ?
Offline Salman_z8
    • Fast Track Signs
« Reply #195 on: June 22, 2023, 10:18:59 PM »
Where is the fuel level supposed to be, at 26mm ?
4mm below the seam ?
« Reply #196 on: June 23, 2023, 04:17:21 AM »
I was never able to synchronize my K0 carbs, with any consistency, until I installed those top gaskets. Why leave them out?
Offline Salman_z8
    • Fast Track Signs
« Reply #197 on: June 23, 2023, 12:02:45 PM »
I can get them synced pretty good, but i will try the gaskets.
I never put em in, just because all the ones i have taken apart, never had them.
Will try that
Offline Salman_z8
    • Fast Track Signs
« Reply #198 on: June 23, 2023, 03:24:32 PM »
Since, the bike in question has an unknown cam, stock honda, but of unknown year, could that make a difference ?
Offline Salman_z8
    • Fast Track Signs
« Reply #199 on: June 23, 2023, 03:27:08 PM »
Took the other bike out, and it is so effortless to accelerate.
It does have some mild intake port work.
Now i want both of em to be similar.
Both have same airfilter, same oil, b750A carbs, similar jetting, same electronic ignition.
One has yamiya no number pipes, other ( the one in question ) has later hm300
