Author Topic: 1973 CB 750 Rebuild.  (Read 4292 times)
Offline Grizzy
« on: December 27, 2017, 05:10:03 PM »
Just finished getting my work area ready, has some heat at least!
Bike is not running but turns over freely. Going to take apart just about everything. Starting with good intentions...labeling everything that comes off and putting into baggies or containers. Also lots of pictures along the way
Offline Grizzy
Re: 1973 CB 750 Rebuild.
« Reply #1 on: December 27, 2017, 05:11:25 PM »
I have gone thru all the Hackaweek videos on YouTube for the 73 750 rebuild, going to be a big help
« Reply #2 on: December 27, 2017, 06:06:44 PM »
What do you plan to do with the engine?
Have you tested compression or given it a leakdown test?
Offline Grizzy
« Reply #3 on: December 27, 2017, 06:44:00 PM »
Bike has 17k miles, new rings for sure, everything else depends on what I find.
« Reply #4 on: December 28, 2017, 08:56:56 AM »
I have a headlight can from a 73.
« Reply #5 on: December 30, 2017, 07:20:58 AM »
Sorry, left out it's available if you need it. I have some other 73 pieces too.
Offline Grizzy
« Reply #6 on: December 30, 2017, 12:05:42 PM »
Thanks Mauik3, nearly have everything taken off and will make a list of what needs to replaced soon
Offline Grizzy
« Reply #7 on: January 07, 2018, 05:24:59 PM »
bike now in about 100 baggies and plastic containers...well labeled!
Starting engine teardown, so far things looking fairly good
Offline Grizzy
« Reply #8 on: January 12, 2018, 02:58:24 PM »
I was feeling pretty good about what I saw on the top end and then pulled off the drain pan. Screen was covered with debris. A lot of it feels like silicone sealer.
« Reply #9 on: January 12, 2018, 07:15:31 PM »
Looks like someone blackened the oil pan!
Offline Grizzy
« Reply #10 on: January 13, 2018, 11:30:08 AM »
Black oil for sure, been sitting a while. When I dragged a magnet through the crud a fair bit stuck to it,
Offline Grizzy
« Reply #11 on: January 14, 2018, 01:40:03 PM »
I have removed 14 of 16 cylinder studs using a double nut on top and vice grips near the case. I’ve tried heat on the studs, lubricant (wd 40), tapping with a hammer and no luck. Really worried I’m close to breaking one off.
Any suggestions out there?
Something better than wd40?
Thanks
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #12 on: January 14, 2018, 02:12:33 PM »
pb blaster
« Reply #13 on: January 14, 2018, 03:01:50 PM »
pb blaster
+1.   Or Kroil.   And heat.....
Offline Grizzy
« Reply #14 on: January 14, 2018, 03:33:33 PM »
I have used heat on studs, afraid to heat the case
Offline Grizzy
« Reply #15 on: January 15, 2018, 09:20:11 AM »
Any opinions on leaving the 2 frozen studs and using 14 hd on the others?
I figure breaking one off is the worst ‘option’, maybe just accept that 2 will be the originals
Offline JoeCooley
  • Long time lurker, but now I'm a
« Reply #16 on: January 15, 2018, 06:41:40 PM »
I wouldn't recommend it. Use heat on the case around the studs. The aluminum should expand quicker and help release. You can also try heating it and applying candle wax to the base of the stud. The wax will go into the threads. This is an old school trick a machinist friend showed me. If all else fails, cut the stud shorter and have a nut welded on. Then get a socket and big breaker bar.
Joe in San Diego - Quick Cyles
78 CB750K 836cc Highway Racer - http://forums.sohc4.net/index.php/topic,162264.0.html
Rickman CR750 Restoration (SOLD)
Offline Grizzy
« Reply #17 on: January 15, 2018, 06:54:23 PM »
Good tips, shortening the stud makes sense, getting a lot of twist right now and fear any more force will break it....going to give it a try, thanks
Offline JoeCooley
« Reply #18 on: January 16, 2018, 03:34:34 AM »
That's pretty much what will happen. I snapped a couple when I did mine. Just remember to apply heat to the aluminum, not the stud. The stud will get hot but aluminum conducts heat better. You don't want the stud to expand. Do circles around it with your torch to evenly heat it. Just be carefully not to melt the case. You should be fine with a propane torch but oxy/acetylene will get hot enough to damage the case.
Offline Grizzy
« Reply #19 on: January 17, 2018, 03:57:55 PM »
Woo Hoo! Got the last 2 cylinder studs off!
I tried using wax, didn’t work right away but after heating and tapping with a hammer they finally came
Thanks for all the suggestions
Offline JoeCooley
« Reply #20 on: January 17, 2018, 05:07:26 PM »
I'm glad it worked out for you. I have a set of low mile 78K pistons if you need them. Worth beer money... It'll give you a small bump in compression...
« Reply #21 on: January 21, 2018, 08:46:54 AM »
I have some 29,xxx mile pistons and pins, good shape, came out of my K3 750, was running. I put in .5mm over pistons.
Offline Grizzy
« Reply #22 on: January 21, 2018, 10:56:26 AM »
 Got them rebuild project blues!
Having a hard time splitting cases so I double checked number and location of bolts. Found where a upper case bolt should have been is GONE!
The cases have been welded together, just in front of the front sprocket. Chain must have come off and put a hole in cases and it was welded over.
Bike was really dirty when I got it you couldn’t see the weld through the gunk. It isn’t running and I planned taking cases off when I started and painting them, didn’t do a detailed cleaning.
Time to come up with plan B
« Reply #23 on: January 21, 2018, 11:38:54 AM »
Wow, that's a new one.  You sure it's not JB Weld, a common fix for broke case.
My plan B would be throw in my spare motor....but you may not have one, yet?
Offline Grizzy
« Reply #24 on: January 21, 2018, 12:17:59 PM »
Could be, found set of cases on eBay under $100, looks like plan B
