Author Topic: Velocity Stack Filters  (Read 8127 times)
Offline Rocketman
« on: December 28, 2017, 06:11:13 PM »
Thinking about adding air filtration to my CB550.  Currently using Keihin CR29s with open velocity stacks.  First thought was a still air box or something like the ITG filters discussed in the forum post.  http://forums.sohc4.net/index.php/topic,79491.0.html
While search around the internet I cam across a firm offering both their own stacks for CR carbs with metal filters or filters for stock Keihin velocity stacks.
http://www.pjmotorsports.com/velocity-stack-filters.html
Anyone have any experience with velocity stack filters they can share?  What ever I do will be dyno tested when the motor goes back together.
« Last Edit: December 28, 2017, 06:12:52 PM by Rocketman »
Offline KeithB
Re: Velocity Stack Filters
« Reply #1 on: December 28, 2017, 06:29:37 PM »
Any kind of filter or screen in the throat of a velocity stack will negatively impact the whole point of the stack.
The "still air box" is a better idea, like the stock box on a CB750.
But I suggest you first get your bike on the dyno and see what really works to make a good HP and torque curve.
 Two Tired has a great post on velocity stacks on this site. Have a look for it...good reading!
Nanahan Man
« Reply #2 on: December 28, 2017, 07:44:41 PM »
Martin, I use Mic smoothbores and had stacks made then use dual sock foam filters over the stacks. Mine will have a different spacing but you can surely find a spacing to fit. From bellmouth inlet to back of the filter is 45mm. Just an option.
No filter is ideal obviously but anything directly over the end of the bellmouth will create negative issues.
http://www.ramair-filters.co.uk/shop/motocross/sock-filters-motocross/2-x-twin-inlet-carb-socks-2/
Offline slikwilli420
  • Master of Disaster
« Reply #3 on: December 29, 2017, 07:03:20 AM »
I'm using the same setup as Brent on mine. I cut down Weber DCOE stacks to fit my carbs and added a filter from ram-air.
Offline turboguzzi
« Reply #4 on: December 29, 2017, 07:15:13 AM »
in modern superbikes, it's common knowledge that airboxes actually help power if designed right, so not a bad idea. im considering building one for my 500/4.
mesh over the stack feels wrong, but air never does what you think, so now that i have my flow bench up and running, will try some mesh over an open stack and tell you exactly if and how much flow you loose.
Offline simon#42
  • liverpool
« Reply #5 on: December 29, 2017, 07:43:11 AM »
you wont loose any flow at all , the drop in performance comes from messing up the harmonics of the inlet . anything close to the end of the inlet of the carb will cause a pulse wave reflection
which almost always is bad .
why do you need air filters anyway , you dont go racing to make engines last a long time !
« Reply #6 on: December 29, 2017, 08:01:18 AM »
Well actually Simon....I don't mind a bit if they last!  ;) This is middleweight vintage, but each to his own.
I do understand what you say however, we piss money into the wind on the best of days. What's an extra top end work now & then?
At Barber in October when my bike slid into the gravel trap I was pretty happy to have those filters. We were back out in no time.  ;D
« Reply #7 on: December 29, 2017, 08:32:51 AM »
I would never run without filters. My head cost $2 grand and replacing items more often than necessary for a SLIGHT power advantage is foolish. Hit a gravel trap and suck in an engine full of crap and not only is your weekend over but it may cost enough to keep you from other events.
Offline simon#42
  • liverpool
« Reply #8 on: December 29, 2017, 08:37:03 AM »
be thankful you race a honda 4 brent  back when i raced rg500s and crashed most weeks i spent far to much of my life looking for where the carbs had landed
and digging mud out of the crankcases . during one particularly graceless crash at snetterton it actualy ate a turnip !
« Reply #9 on: December 29, 2017, 08:50:46 AM »
Hahaha, I love turnip! Things do get airborne. One of my more spectacular get-offs popped the crabs off, plus launched my brand new Krober 200+ feet. Tyler found it all and the Krober even worked although we needed a new frame.
« Last Edit: December 29, 2017, 08:55:10 AM by bwaller »
Offline NickO
« Reply #10 on: December 29, 2017, 12:02:35 PM »
My mate raced his TZ750 this year for the first time in many many years.
It was set-up very "safe" (i.e. rich) and had the gauzes fitted to the stacks.
Afterwards on the dyno it was only showing about 100hp, but removing the gauzes saw an immediate improvement to 110hp+.
« Reply #11 on: December 29, 2017, 01:52:30 PM »
Well I'd be a tad careful with a big TZ too. Not so easy finding parts anymore, really have to make those things last.
Good on him for getting it out.
Offline simon#42
  • liverpool
« Reply #12 on: December 30, 2017, 04:22:43 AM »
parts are not so bad these days , the main problem was getting a good set of crankcases . the design is not very good and they damage easily .
they never make the same power after they have been repaired . there where some very good french [ jpx ] made cases made in the 80s but these have long gone
there are now some being made in australia which look to be very well made and should solve that problem . other than that all other engine parts can be found .
if you wanted an original master cylinder or something you would struggle though . not sure why more people dont race them these days they are easy to set up
and nice to ride , its only when you have got one right on the limit ...... then they have a habit of showing you who the boss actually is .
Offline MessnerMoto
« Reply #13 on: December 30, 2017, 04:38:37 AM »
I designed and made for my project... Velocity stack plus UNI filter. 3d printed.... I dont have any numbers but vacuum pull from carbs sounds crazy
« Last Edit: December 30, 2017, 04:40:59 AM by MessnerMoto »
Offline turboguzzi
« Reply #14 on: December 30, 2017, 06:01:45 AM »
flow bench results are in...
didnt have metal mesh, so used some mosquito net that has 0.13mm strands
for the sport, also tried a layer of 1/2" gas tank foam.
so then:
bellmouth free - 80 CFM @ 28" H2O
one layer of mosquito net - 78 CFM
two layers mosquito net- 77 CFM
tank foam - 76 CFM
Simon is almost right, very little impact, just -2.5% for the mesh, honestly was expecting lot worse for the net and better for the foam, turned out the other way around. air flow surprises you indeed.
the metal mesh could of course make things worse if strand diameter/mesh density is higher
Regarding foam, with more area for filtering like in the nice stacks of mirko and brent, loss would be way lower for the foam.
FYI
« Last Edit: December 30, 2017, 06:05:30 AM by turboguzzi »
Offline Rocketman
« Reply #15 on: December 30, 2017, 06:22:48 AM »
Good information. Definitely going to add filters. Multiple ways to go. Thanks to all who responded.
« Reply #16 on: December 30, 2017, 06:52:19 AM »
Good sleuthing TG.
Very nice solution Mirko
Offline MessnerMoto
« Reply #17 on: December 30, 2017, 07:38:25 AM »
Yoss you can experiment, if you have time, and create rounded mesh/wire.... something simple. Probably losses would be way lower like u commented... without my fancy stuff ;)
would be great to see some actual numbers....
« Last Edit: December 30, 2017, 08:01:26 AM by MessnerMoto »
Offline simon#42
  • liverpool
« Reply #18 on: December 30, 2017, 10:37:52 AM »
i normally see a loss of 6 to 8% on the dyno ,  the engines dont seem to care how pretty they are sometimes the ugly ones are better sometimes not .
Offline gschuld
« Reply #19 on: December 30, 2017, 11:03:31 AM »
Mirko,
Very impressive work..... 8)
Have you considered adjusting the design to cover factory cb750 round top carbs?
George
« Last Edit: December 30, 2017, 11:06:09 AM by gschuld »
« Reply #20 on: December 31, 2017, 06:49:34 PM »
The open stack flowed less than your port??
Offline MessnerMoto
« Reply #21 on: January 01, 2018, 02:28:25 AM »
Mirko,
George
Send me ID, OD and distance between ODs of two outer carbs....
Offline turboguzzi
« Reply #22 on: January 01, 2018, 04:14:49 AM »
[/quote
Look at the pic. No head just a stack over the 80cfm hole in the calibration plate
Offline gschuld
« Reply #23 on: January 01, 2018, 06:28:24 AM »
Mirko,
George
« Last Edit: January 01, 2018, 06:30:51 AM by gschuld »
Offline KeithB
« Reply #24 on: January 01, 2018, 07:18:52 AM »
How did you arrive at the shape and size of the stack?
Nanahan Man
