Author Topic: Advice about a seized engine.  (Read 6146 times)
Offline Hotwheelbill
« on: January 07, 2018, 12:49:02 PM »
So, my 1972 CB750 is still seized. I have pumped fork oil, transmission fluid, diesel fuel, and much Aero Kroil into the spark plug holes. I tried to rock it with the points nut and broke off a tooth on that washer. I have tried the kick-start and have put more that I am comfortable with pressure on it. What other leverage points can I use? There is no chain on the bike Right now.
I love to make my bikes worthless due to high mileage!
2004 ST1300A .... the fast one. And dragging pegs on a CT.
1972…parts bike
1974…. Rusty frame but runs
1974 CB750..... Powder coated frame and parts, waiting for $$ hot rod motor.
1972 with 1975 old school drag motor
Offline DV Red Herring
  • Army RETIRED
Re: Advice about a seized engine.
« Reply #1 on: January 07, 2018, 12:51:30 PM »
How long has it been soaking?
« Reply #2 on: January 07, 2018, 12:53:47 PM »
 Pull the alternator cover off the left and use a breaker bar on the bolt head in there inside the rotor..
« Reply #3 on: January 07, 2018, 01:07:35 PM »
+1 try turning the crank on the stator end, never the points side.
Even better is to rock the entire bike while in third gear with the plugs out.
Can make a nice shooter when she frees, I have the record - 17'!
« Reply #4 on: January 07, 2018, 01:08:59 PM »
One day.
1972…parts bike
« Reply #5 on: January 07, 2018, 01:11:38 PM »
Will do. Thanks for the advice. I have no choice but to let it sit a few days as I will not be able to be back at it until later in the week.
1972…parts bike
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #6 on: January 07, 2018, 01:34:02 PM »
Why would you want to "unlock" a seized motor without taking it out of the bike and remove the head? You will have to look at the cylinders and rework them anyway. If a piece of ring brakes off and you fire the engine, you do more damage.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
  • Army RETIRED
« Reply #7 on: January 07, 2018, 01:39:01 PM »
Acetone and Trans Fluid is a better concoction. It may well take more than a few days to get it to unlock, especially if you can’t get a lot of fluid into the motor.
I had a motor that I literally soaked on and off for 6 months and never got it to unlock. Had to pull the head and BBQ the pistons, AND STILL use a breaker bar.
That's one way to get them hot!!!
« Reply #8 on: January 07, 2018, 01:43:58 PM »
Why would you want to "unlock" a seized motor..
A "stuck" motor is typically the rings rusted to the cylinder. It will be a lot easier to remove the cylinders if the motor is freed up.
Trust me, I've been there.  A stuck cylinder can be a real bear to get off without damage.
« Reply #9 on: January 07, 2018, 01:57:44 PM »
not to mention that it's surprisingly common for these engines to run fine after getting the rings freed up
Offline Cormz02
« Reply #10 on: January 07, 2018, 02:06:27 PM »
Marvels mystery oil worked for me, I let it soak maybe 4 hrs and then slowly worked it and it came free.
« Reply #11 on: January 07, 2018, 02:16:10 PM »
Yep, the F engine I initially used in my K2 "Bitsa" came out of a Seeley that sat for many years, and was locked up when the new owner bought it, and from what I'm told it took a lot of effort to un-stick, but runs fine now. Don't pull them apart unless it's absolutely necessary! ;D
Offline carnivorous chicken
« Reply #12 on: January 07, 2018, 02:39:28 PM »
I'll third that...
Offline setdog
« Reply #13 on: January 07, 2018, 02:41:30 PM »
One day.
Unless youre in a hurry, just let them soak for several more days at a minimum.  Maybe even until next weekend.
I would just try bumping it every few days.
whatever you do, DO NOT be hasty, heard many stories of people bumping the rings free and then not having to rebuild
so please, take your time.
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
« Reply #14 on: January 07, 2018, 05:00:44 PM »
It depends what you want to do with it.
 If you are parting it out, you may want to sel, it in one lump.
 I think that one had bad fins on the head.
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #15 on: January 07, 2018, 06:26:48 PM »
...looks like a hot spot to bbq a filet mignon wrapped in bacon... and the drippings might act like a penetrating oil! Yeah... that's it... penetrating oil.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline gwallis
  • 1976 Honda CB550F 1973 Honda CB750
« Reply #16 on: January 08, 2018, 05:38:44 AM »
Marinade in Marvel's Miracle Oil for several days... preferably with some kind of Hot Plate under the engine... then rock back and forth in 2nd or 3rd gear.
That's what has worked for me in the past.
Offline b52bombardier1
« Reply #17 on: January 08, 2018, 06:15:40 AM »
Use some 1000 watt heat gun heat or a propane torch kept moving around the heads to speed things up a little.
But never be in a hurry. Let the chemistry and heat work for you.
Rick
Sent from my SAMSUNG-SM-N900A using Tapatalk
1971 School Bus Yellow Aermacchi H-D Sprint 350
1972 Candy Yellow CL100 K2
1972 Candy Jet Green Honda CB500
1973 Mighty Green ST90 K0
1974 Mars Orange CT90 K5
1975 Topaz Orange ST90 K2
1976 Shiny Orange CT90
2006 Honda Foreman 500 (restored)
« Reply #18 on: January 08, 2018, 06:41:22 AM »
+1 on the heat. Can't hurt and might get a little metal moving around and better seepage. Did the heat gun on a 350 Kaw Triple along with some soak and believe it helped. Ports on a two stroke make it hard to 'fill' the cylinder depending on where the piston is situated.
  Its pretty much dependent on how a bike was stored if a seized engine will live again. All tucked away in a nice dry pole barn or garage good chance maybe. Stored outside in the elements for a long time with open carbs etc--good luck but probably should come apart. Another cause for a seize could be a torn up top end. An oil drain or sump pan inspection for debri can give those clues as well as seeing if water is in there.
« Last Edit: January 08, 2018, 06:46:31 AM by ekpent »
« Reply #19 on: January 08, 2018, 06:58:38 AM »
Engine stucked after years of mo care. Give the chemicsls a week to penetrate. Heat the cylinder block witj a heat gun until you’ll smell burnt oil, an hour or more. Too much physical force will harm the engine.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #20 on: January 08, 2018, 01:12:25 PM »
50/50 blend to be exact. Don't try and hurry the results too much or you might break more than what was already broken.
« Reply #21 on: January 08, 2018, 01:33:16 PM »
 I have a 10,000 mile engine that had 10 oil changes then left in a barn for years with the carbs off. I had a strap wrench on the rotor and a ratchet strap holding tension on it while heating it lol. It's still stuck, the cylinders that had open valves were full of rodent waste. When I decide I have time to clean it up I'll split the cases, hopefully the trans and bottom end are OK.
  I have another one that was leaned against a clothes line pole for years outside with no carbs, the ports were stuffed with shopping bags and it was as clean as a whistle inside. You never know. I hope yours is like this one.
« Last Edit: January 08, 2018, 01:35:27 PM by Don R »
« Reply #22 on: January 13, 2018, 05:06:55 PM »
So, I got around to that today and turning it counter clockwise like I should only loosened the bolt. Put some arm on it in the clockwise but just really tightened the bolt......Don't want to break anything.
1972…parts bike
