Author Topic: Oil temp gauge?  (Read 4625 times)
Offline Deltarider
Re: Oil temp gauge?
« Reply #25 on: January 16, 2018, 07:37:22 AM »
A Deutz tractor was the first vehicle I drove at the age of six, be it under supervision of the owner/farmer. Unfortunately the Search function is down. In the past I have written extensively about monitoring instruments including VDO gauges that had a programmable threshold. Ideal.
« Last Edit: January 16, 2018, 07:42:11 AM by Deltarider »
CB500K2-ED Excel black
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=asdm6qigqjosb4io2nis2r4dc0&/topic,60973.0.html
Re: Oil temp gauge?
« Reply #26 on: January 16, 2018, 11:17:47 AM »
mine Deutz vas a d-15...it had a kontra balance shaft to give a softer run of the 750cc 1 cyll aircooled engine..the erlyer model you have on  Photo..did not use that..the gearbox vas a fridrichhafen zahnrad fabrik fabrikat Z-F.. used in most germen fabrikated heavy mateiell..from tanks to buses..
later i got a 9006 tractor..it had a aksial blover for cooling..but the engine vas in prinsip the same as the small old one..later i thanged to ih 1455 germany made ih tractors the best tractors ever made....but that is off topic...
« Last Edit: January 16, 2018, 11:22:05 AM by strynboen »
i hate all this v-w.... vords
Offline oatmeal400f
Re: Oil temp gauge?
« Reply #27 on: January 20, 2018, 02:26:06 PM »
Hey I came across this on Instagram
Looks like what you are looking for, also checks voltage
Made by yoshimura
That's all the info I have
Hope it helps your search
