Support the site. Your contributions keep this site running.
cotter pins if external can include a bent rusty nail.
trouble is Honda and other brands just don't use the standard metric sizes,theyll use some oddball like 13.7mm not quite a square 14mm for sizes,you can get by with the rounded up sises in the larger sizers,they don't quite equate to imperial either,the reason is ya gotta buy genuine,the savvy amoung you now can spot ive spelled sizes and sises and sizers,thats just to check your all paying attention to detail!
your alert yamabird!its the millenials ya gotta watch out for!
https://www.harborfreight.com/397-piece-metric-o-ring-assortment-67580.htmlThere's enough different sizes that I can usually find one that will work, except for those specialty rings and the large diameter ones that honda uses and they are nitrile so they can be used around gas. There's enough different sizes to have this set pay for itself pretty quickly. I do try to replace o-rings whenever possible, same with seals that aren't easily accessible.
