Author Topic: Cb550 starter relay wiring  (Read 4292 times)
Offline Alexandlinda
« on: January 21, 2018, 07:36:05 AM »
I'm in the process of restoring my 550F and I am confused about the wiring on the starter relay behind the LH side cover.
The wires for the starter solenoid are off but I'm not sure which ones go onto which of the two terminals. The terminals on the relay do not seem to me identified with a + or -.
Can anyone help? Pictures would be really useful too!
Thanks
Alex
Offline cadman
Re: Cb550 starter relay wiring
« Reply #1 on: January 21, 2018, 02:54:48 PM »
The starter solenoid is nothing more than an electric switch for the starter.  There are two large posts.  One side attaches to the battery the other to the starter.  When the solenoid is actuated it completes the +12VDC circuit to the starter.
Offline Smudgemo
  • Maker of Stuff
« Reply #2 on: January 21, 2018, 03:32:13 PM »
My '76 550F
Honda Electrics by , Smudgemo on Flickr
« Last Edit: January 21, 2018, 03:35:02 PM by Smudgemo »
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
    • http://forums.sohc4.net/index.php?PHPSESSID=qjop12ch7itsine2lkb3rl9ot6&/topic,60973.0.html
« Reply #3 on: January 22, 2018, 08:12:40 AM »
it are only the positive voltage vho goes through the big kontaktors...så both are positive plus.
..the netative energy goes through the frame and frame viring..so are alvays konnekted
..thats vhy, its so importment to have a good frame konnektion..its the half of the power"s vay..
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« Reply #4 on: January 22, 2018, 08:42:40 AM »
Hi Alex,
  Good luck on your CB550F, and welcome to the forum!
 The answer is, when you mount your solenoid so the your small wires are correctly connected together, the cable from the battery will mount on the lug side closest to that and the starter cable will mount on the other conveniently located screw lug. It matters not, which one goes where, as was stated, they are both for +12v. connection, and the two small wires, when actuated, will make the contact in the solenoid between the two lugs.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
« Reply #5 on: January 22, 2018, 10:35:25 AM »
Thank you very much for the responses. I slept on it and sort of arrived at the same conclusion but being electrically challenged I am very glad to get clarification. Just a final clarification... I get that the power comes from the battery to one terminal and out to the starter from the other.. does it matter at all which terminal the remaining wires go to?
Thanks!
The bike is coming on nicely and should be on the road by spring. I hope to take it on the Exmoor Dash (or whatever its called)..
« Reply #6 on: January 22, 2018, 12:02:50 PM »
the terminal vith 2 vires ,is the battery konnektion..it have alvays power..the start konnektor brigde over to the singel pole..vho goes to the starter...both poles is isolated..so put the vires hvere they fit best..
Offline Yamahawk
« Reply #7 on: January 22, 2018, 12:25:58 PM »
Thanks!
Ah, yes it does. The ring terminal in your picture, will go to the battery side of the solenoid.The other two wires with the bullet connectors are color coded, and should be keyed to the bullet connectors. If not, then hook the up as per each color coded set.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
« Reply #8 on: January 22, 2018, 02:02:45 PM »
You're English is not bad! Thanks for the advice. I think I can do it now!
Offline Yamahawk
« Reply #9 on: January 22, 2018, 02:07:30 PM »
....I was taught to read and write with phonics! hehe... I went downhill from there.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
« Reply #10 on: January 22, 2018, 02:09:44 PM »
Thanks again to Charlie and Strynboen,
I have it figure out now thank you. Just didnt want to blow anything up!
Almost ready, lights and brakes next..
« Reply #11 on: January 22, 2018, 02:12:05 PM »
Thanks for the useful pic Smudgemo and advice from Cadman.. all really helpful. this is my first venture onto the site and its brilliant!
Offline Yamahawk
« Reply #12 on: January 22, 2018, 05:43:48 PM »
Alex,
  That's a nice looking CB550 SuperSport! I bet she'll run really well for you!
Charlie
Edmund Burke
Romans 8:28
Job 13:15
